RicardoGray
Flight distance : 4356421 ft
Shakey Steve Posted at 2017-6-19 06:49
Yes, I copied only the .bin file onto the root directory of the SD card. I did this many times with 4 different SD cards and still the camera would stop reading after 10 seconds. As for not upgrading the firmware, I believe it needs this upgrade for both the drone and the RC for it to actually give me basic functionality for the camera, but I will check that when I get home from work today and report back details. Thanks.
Yes if you upgrade, you will have one for the phantom and one for the RC. And they have to be the correct ones for that version of the firmware. Not trying to confuse you, but they will not be the same versions for both. I hope that makes sense. To be clear, you can't just upgrade either one by itself, they cannot "hand-shake" and you won't get any communication between them. The Phantom should show the same as the firmware version, but the RC will be a different one. Which version are you on? You should be able to look in your app in the "about" section. Unless you have managed to upgrade one or the other, it should fly.
Also make sure you have the right one for your phantom. You have the P3P right. The firmware for the Advanced will not work because you have a 4K camera. Just trying to help you here, not trying to confuse you.
It would be hard to imagine, but if your phantom has an older version of firmware....I'm thinking like V1.3 or V1.4, or something like that, you cannot jump right up to V1.10. Just something to consider. Need to know what you are on for sure I guess. After version V1.5 or V1.6 I think is when you can go right to the latest version, and with those it is generally done through the app. But the old way by copying the bin file to the card should work if all else fails. Seems odd that if is just now being taken out of the box, it should work.
I'm guessing you can read the card on your computer ok right? Is there a text file? There should be. It should shows some info on what is going on, unless it simply doesn't even try to read the sd-card.
So, from what you are saying , you think it starts to read it for a couple seconds but then stops. If that is the case it sounds like there should be a text file there. You may see that it thinks the phantom is on the correct version. It should say something like "aborted", due to same version. The RC must be upgraded through your WiFi, even if your phantom is on the right version. It will not upgrade the RC from the sd-card in your aircraft. Hope this gives you some things to try. Good luck. |
