LOS at a 100ish feet, why? What am I doing wrong?
12Next >
3127 42 2017-6-19
fans3c8754d6
Hi all, I'm new around here but I did do some reading before posting.  I'm not finding much and thought I'd ask directly.   We have a park near the James River that is some what wooded and I'd like to fly here, but every time I get LOS and then it returns home.  I've got a quick video here to illustrate.
I'm the guy in the middle near the orange cone.  You can see the point that is stops responding and starts to RTH.  I was able to re-establish connection on its way down by turning off my controller, and then turning it back on.
2017-6-19
bomberuk
Flight distance : 16759 ft
are you flying with the gimbal cover on,thats a bad idea because it restricts the air flow to the fan thus causing over heating ;)
2017-6-19
RCNJ
Flight distance : 114665 ft
Unsure pal but is that the gimble cover flickering on screen ? The sun can stop it if facing towards sun but don't know why it would rth...
2017-6-19
ProQuad
Flight distance : 20296870 ft
Fans3c8754d6,
LOS is Line Of Site and was a little confusing the way you have it.  No biggie, I figured it out, but for future use.
If your gimbal cover was on, please remove it before each flight.  There is a fan that needs to run to help cool the internal components.
As far as the RTH are you running the latest firmware?  Have EVERYTHING calibrated?  The IMU (cold IMU calibration), compass, vision systems, camera, remote, etc?  Have the latest DJIGO4 app?
If all of this is up to date and you still have issues, contact DJI support, they may want to have you send it in to have a look at it.
2017-6-19
Thecavemankevin
Yes, I forgot to take the gimbal cover off.  Normally don't do that.
I thought LOS was loss of signal...sorry about the confusion.
Yes, it is running the latest firmware and Go4 app.  I'll re-calibrate it and try again tomorrow if the weather is good and report back (come to think of it, it has been a while since it has been calibrated).
2017-6-19
levani27
Thecavemankevin Posted at 2017-6-19 09:38
I had same issue yesterday in Darlington park in Canada, Ontario.  Couple days ago I did fly near lake Ontario with no problem at all.  I'm loose connection near in 10-20 meters!!  Could be very strong  radio interference, amount of GPS satellite dropping from 17 to 3 simultaneously.  Have nothing else to say, there is a nuclear station nearby.
2017-6-19
Ex Machina
Flight distance : 1806362 ft
Don't calibrate anything unless prompted to do so.
Are you getting warnings about signal interference? Does this happen at other locations? Does the remote view screen show low signal?
2017-6-19
AG0N-Gary
Flight distance : 700846 ft
If I'm not mistaken, you lost signal right overhead.  I doubt it would cause the problem when you were only a few dozen feet above you, but did you re-orient the antennas when you were overhead?  I'm assuming that's you with the controller at the middle of the path opening.  The overall behavior doesn't look like loss of signal.  RTH would have landed it right where it was, since you were so close to HOME, assuming you took off near where you were standing.  You obviously didn't lose signal, because you turned it 90 degrees (toward the trees) before landing.  With RTH activated, it would turn toward home, climb to RTH set height, move to overhead home, and drop down for landing slowly.  Something just doesn't add up.
By the way, LOS to many of us raised with NASA lingo, interpret LOS as loss of signal.  AOS is acquisition of signal.  Pretty natural confusion on today's world.
2017-6-19
Thecavemankevin
Ex Machina Posted at 2017-6-19 09:55
No, i've not been prompted to re-calibrate.  But I think i'll do a compass re-calibration anyways.
Now, this is a brand new mavic (just bought at sams club earlier that day).  This is my second mavic as my first one (which exhibited the same problems several times prior at the same park) crashed for a similar reason a week ago.  I have it insured (not DJI care) and they paid full replacement value.  But the new one that you see in this flight did not ask for compass calibration.
The previous mavic was flying in a slightly woodier location half a state away (I should have had it in tri-pod with RTH off, i've learned my lesson now).  I was right beside it, it lost signal and started to ascend to 150 ft (my RTH height) and clipped some tree branches.
I've now had this lost connection on two different mavics when I'm very near by.  I've had it happen with the antenna both in a direct vertical position and at a 90 degree position.
2017-6-19
Thecavemankevin
AG0N-Gary Posted at 2017-6-19 10:07
I took off from right about where I was standing and where it landed.  The entire flight was about 2 minutes.  I took it out over the river and had control until you see movement stall at about 7 seconds on the video.  Then at 18 seconds (after loss for ~10 seconds) you see it automatically ascend as it is RTH.  At that point in time, I waited until about 30-33 seconds and shutdown my controller.  Then turned it back on.
I hit the pause button on the controller at 48 seconds when I reestablished connection.  I then manually guided it down for landing.
I didn't look at the controller at the time to see what the signal/gps connection were like.  I do know that I also was not able to have streaming video on my phone (samsung Note 7, less than a year old) for 90% of that flight.  Basically about the same time I lost connection originally.
I hope this clears up any confusion
2017-6-19
GTstrudl
Flight distance : 102615 ft
In the video provided, I have seen couple things at least I won't do:
1. I won't fly MP overhead. At that moment, your RC antenna tips point to MP. This might trigger RTH.
2. I always fly MP with my RC antenna extended facing the MP. I saw you facing East while MP flew South.
3. While MP in the air, I will maintain and make sure there is no obstructions, buildings, or trees between my RC and MP.
Good luck. I think both of your MP are function OK
2017-6-19
Thecavemankevin
GTstrudl Posted at 2017-6-19 10:56
I'm not quite sure I understand what you're talking about?  By MP, you mean mavic pro?  In this instance, my controller antenna are pointed toward the mavic and I was facing it the entire time.  As a reminder, I'm on the sidewalk near the orange cone, not on the dock.
2017-6-19
GTstrudl
OK, ignore my point #2.
My point is if you fly MP (Mavic Pro) in an open field your successful rate would be much higher. In your case, you were surrounded by trees almost 340 degrees.
2017-6-19
Thecavemankevin
GTstrudl Posted at 2017-6-19 13:21
Got it, and to my point, what are the settings some people use with success to fly in these kind of conditions?
Same i guess could be said for indoors too where GPS is poor or non-existent.
2017-6-19
Ex Machina
Thecavemankevin Posted at 2017-6-19 10:27
So no warnings about signal interference?
If you want, you can upload your flight records to https://healthydrones.com/main?a=upload and let us take a look.
2017-6-19
Thecavemankevin
Ex Machina Posted at 2017-6-19 14:35
Nothing that I noticed.  I'll try and pull the logs tomorrow.  I'll also try and go back to the same park and do another flight after compass re-calibration
2017-6-19
Ex Machina
Thecavemankevin Posted at 2017-6-19 15:15
An improperly calibrated compass will have zero effect on signal. You can also view the warnings for your flight in the DJI Go 4 app under general settings.
2017-6-19
Thecavemankevin
Another question is why is this happening?
It is pretty common for me to have connection via the RC, but nothing on screen (note, I've mostly had this in similar, wooded or slightly wooded conditions).   Note, this picture what taken indoors, but not flying.
2017-6-19
Ex Machina
Thecavemankevin Posted at 2017-6-19 15:44
[view_image]
If you are inside, then it's likely that GPS signals can't reach your Mavic and it switches to ATTI mode.
Another thought about your Android device connectivity problem -- have you tried swapping out cables and/or checking for pocket lint in your phone's jack? A few people have reported problems with pocket fluff causing bad connections, and a few more have reported having flaky cabling.
2017-6-19
Pilot747-4
Flight distance : 12287 ft
[view_image]
I have this problem very often. Usually after RC connection loss or after tuning RC off and on. Solution: disconnect cable from the phone or from the RC (whatever is more convenient for you) and connect it again. You'll get your RC connection back in the app. My DJI Go (latest version) is running on Android.
2017-6-19
DroneFlying
Flight distance : 10774613 ft
Given the short distance and lack of obstructions between you and the aircraft there's nothing obvious about this flight that would explain the loss of connection. Have you tried flying in other locations and, if so, have you had similar problems when you did? If it works fine elsewhere then it's probably a problem with the environment, but if the behavior is consistent then it's most likely a hardware problem.
2017-6-19
seeker_ktf_
Flight distance : 218474 ft
Two things.  First, was the gimbal bracket on also?  That could cause overheating too.
The other this is, when you say the antennae were pointing at the Mavic, do you mean that the antennae were "flat" against the Mavic or actually pointing at it.  I'm just checking.  In general, flaying close to overhead is potentially bad, ad the Mavic's antenna are really orientated to be able to get the signal from a more horizontal rather than vertical position.  So the combination of bad remote antennae placement and almost overhead could maybe cause a problem.
2017-6-19
Thecavemankevin
I found this video last night with best practices and it was quite helpful.  I think it could have been bad antenna placement in my original video, but I'm not 100%  I've been trying to be better about putting them at about 90 degrees from the controller.  But now I really get it thanks to this video:
I did take the mavic out today to the same park and had a good experience.  No major disconnects (except when I went out about 5000 ft + in distance).  But RTH brought it back and I was able to get control quickly.  However, toward the end of the battery, i had it back out over the water in the same area and I was in about the same area and while I had pretty good control 50-100 ft away, it was very laggy.  Meaning i'd rotate and a few seconds later it would rotate.  The video was about 10-15 seconds behind at that point too.   I was also use the new mavic's controller instead of my original mavic's controller like in the original video
2017-6-20
Thecavemankevin
Ex Machina Posted at 2017-6-19 15:56
Thanks for the tip, I'll double check
2017-6-20
Thecavemankevin
Pilot747-4 Posted at 2017-6-19 16:40
Thanks for the tip, I'll keep this in mind and try it next time.  I've usually just turned off then on the RC.
2017-6-20
Griffith
Flight distance : 98537 ft
ProQuad Posted at 2017-6-19 08:40
Fans3c8754d6,
To avoid confusion, most people here have started using VLOS (visual line of sight) and LOS (loss of signal).
Someone needs to post a recommended acronym list :-)
2017-6-20
seeker_ktf_
Thecavemankevin Posted at 2017-6-20 08:13
https://www.youtube.com/watch?v=P7M9JtfVwQE
Exactly.  Directly overhead with the antennae pointing "at" the Mavic is about the worst possible signal reception situation.
I keep forgetting about all those videos.  It's great that you came back to post your solution.
2017-6-21
hallmark007
Flight distance : 9827923 ft
Thecavemankevin Posted at 2017-6-20 08:20
Are you by any chance in beginner mode.
2017-6-21
Zamboon
Flight distance : 1332844 ft
Zambia
Griffith Posted at 2017-6-20 11:54
From Grumps on this forum back in February:
AC = Aircraft
AGL = Above Ground Level
AMA = Academy of Model Aeronautics
AMSL = Above Mean Sea Level
ARTF = Almost ready to fly
ASL = Above Sea Level
ATTI = Attitude
AUW = All Up Weight
BNF = Bind n Fly (transmitter)
BTU= Blue Tooth Unit
BLOS = Beyond line of sight
BVLOS =Blocked Visual Line of Sight
Cal= Calibration
CA = Collision Avoidance
CAA = Civil Aviation Authority (UK Regulator)
CAAS = Civil Aviation Authority of Singapore (Singapore Regulator)
CL = Course Lock
CSC combination stick command
DJI = Da-Jiang Innovation
ESC= electronic speed controller
FAA = Federal Aviation Administration (US Regulator)
FPV = first person view
FRZ - Flight Restricted Zone
FS = Failsafe
GHz = Giga-hertz
GLONASS = Global Navigation Satellite System (Russian Satellite Navigation System)
GPS = Global Positioning System
HL = Home Lock
IR = Internal Resistance
IOC = Intelligent Orientation Control
IMU = Inertial Measurement Unit
LHCP = Left Hand Circular Polorized
LiPo = Lithium-Polymer (battery)
LOS = Line of sight
MC = Main controller
NFZ = No Fly Zone
MHz = Mega-hertz
MSL = Mean Sea Level
Nicad = Nickle Cadmium
NOTAM = Notice to Airmen
OA = Obstacle Avoidance
OP = Original Poster
POI = Point of Interest
RC = Remote Control
RHCP = Right Hand Circular Polorized
RTF = Ready to fly
RTH = Return To Home
RTM = Read The Manual
Rx = Receiver
SFRA = Special Flight Rules Area
SOC = State Of Charge
SUA = Small Unmanned Aircraft (What the CAA call what we fly)
SUSA = Small Unmanned Surveillance Aircaft (What the CAA call what we fly)
sUAS = Small unmanned aircraft system (what the FAA calls what we fly)
Tx = Transmitter
UAV = Unmanned aerial vehicle
VLOS = Visual line of sight
VRS = Vortex Ring State
VTx = Video Transmitter
VRx = Video Receiver
VPS = Visual Positioning System
WOT = Wide Open Throttle
2017-6-21
Griffith
Zamboon Posted at 2017-6-21 03:42
AC = Aircraft
Thanks
2017-6-21
fans9ffe2d5d
Flight distance : 3504731 ft
AC = Aircraft
Thank you for the list
2017-6-21
Lucas775
Flight distance : 50642090 ft
Are you on beginner mode?
2017-6-21
DennisMurry08
Flight distance : 5948264 ft
Hey Fans...so, Ive had the blank screen on my Droid/Ios ...what I found is if you dont clear the app after using it, sometimes it hangs...meaning hit the button on the phone that shows all the apps that are still running in the background...usually the double window button on the bottom right on the droid or tap the button twice on Ios...you'll see everything thats cached...clear the Go App then go back to the main screen and enter the Go app again....I cant say thats the problem but it has worked for me several times...now once I shut Mav down I also clear the app on what ever device I'm using...hope thats all it is.
2017-6-21
Thecavemankevin
hallmark007 Posted at 2017-6-21 02:55
noooooo  (sorry, have to hit 10 character minimum to post)
2017-6-21
Thecavemankevin
DennisMurry08 Posted at 2017-6-21 07:07
So do you mean you clear the cache after each flight, or simply fully close the app in between flights (or when you don't get video feed back to the phone?
2017-6-21
UCBarkeeper
Flight distance : 616982 ft
Switzerland
the solution is to take another cable and use the other usb port on the RC
to the topic:
i don't really get the signal loss. this should not happen at that distance, doesn't matter if the antennas pointing to the aircraft.
maybe re-pair the rc?
2017-6-21
UCBarkeeper
Switzerland
and jesus set your rth altitude higher or you will end up in a tree.e: in case you had enough distance for the whole "go up" part of rth.
2017-6-21
Deepfreeze
I've had frequent disconnects /LOS when using a samsung tab A. Switched to a samsung Tab s2 and no issuses. Recently used my Nexus 6P, and it also has no isssues. I've flown in heavy wooded areas over 1km away and had no degradation of signal. Try another device to see if it helps.
Here's my last flight:
BTW, the two folks in the canoe were with me , flight was alittle jerky due to my guests asking me a ton of questions . Apparantly I can't walk and chew gum at the same time.
2017-6-22
fanscdfb5121
Flight distance : 236768 ft
I posted a similar thread where I get frequent disconnects. The one thing that seems to be working for me is putting my phone in Airplane mode. When I do that everything seems to work fine.
2017-6-22
ProQuad
Griffith,
I stand corrected.
2017-6-22
12Next >
