Spark Wi-Fi 2.4 Ghz but no 5.8 Ghz available?
5724 13 2017-6-19
RichJ53
Flight distance : 1837356 ft
Hello All Spark owners
Okay I have ben flying my Spark all weekend and found that the remote (RC) works very nicely with the new drone. Also, the device / mobile works very well in closer.
Like most other DJI drones you can go into the transmission tab of the Go 4 App and change channels or signal strength. I have found the Spark is somewhat limited and you can change the channels from 2 - 10 2.4G only
When you are looking at the channel index bar 2 thru 10 and find a clear one, tap and hold the channel number below the signal graph. A pop up will ask you to confirm the change and restart the Wi-Fi.... meaning you will need to open up the mobile device settings and reconnect to the Spark.  screen shots below.. PIB to loose connection with your device everytime you want to change something. Clearly only using the Wi-Fi radio technology only and don't get me wrong it works great so far....   It works the same when only connected to the mobile device too.
Using iPhone 7 iOS 10
What I could not find, is how can you change to 5.8G? I have tapped and held the 2.4G button without any change. I can not find it anywhere.
Feel free to chime in and answer these questions
All the best
Rich
2017-6-19
hallmark007
Flight distance : 9827923 ft
Same as that waiting for an answer....
2017-6-19
neo2ooo
Flight distance : 87372 ft
What device are you using to connect to the RC?
2017-6-19
hallmark007
neo2ooo Posted at 2017-6-19 12:46
iPhone 7..
2017-6-19
RichJ53
2017-6-19
RichJ53
DJI
Can you answer this question please. Would like to know how to switch to 5.8G
Rich
2017-6-20
fansa686c875
I contacted DJI Support about this. It appears that the iOS version of DJI Go 4 may have a bug that prevents 5.8ghz mode. I downloaded the app on a spare Android device I had and it allows the switch to 5.8Ghz mode there. So, hopefully, the app update that DJI announced would be available this week fixes that issue. I'm having issues with my AppleWatch interfering with the controller transmissions so I would like to use 5.8Ghz instead of 2.4.
2017-6-20
RichJ53
fansa686c875 Posted at 2017-6-20 08:00
Thanks for the update and information! It seem logical that the 2.4G button should allow you to change the frequency. I would like to use the 5.8G for clear signal in my area too.  I have lost the RC signal a few times while using the RC remote and it wasn't long enough to start a RTH...
Thanks again
Rich
2017-6-20
hallmark007
Thanks for that, hopefully will get sorted soon.
2017-6-20
fansfdcc5ccf
Flight distance : 233209 ft
Hi all,
using an iphone 7 too, I can state the following:
when using 5.8 ghz, I can reach around  65 m distance ,
when using 2.4 ghz, I get the 100 m.   ,-)
So think about using 5.8 ghz,
2017-6-20
Madwand
Flight distance : 73018 ft
Still waiting for an answer on this.  I just switched to an ipad mini and while setting it up, I had both choices, and then somehow I only have 2.4 now with 5.8 completely gone.  WHY?  Tried with wifi, with OTG, nothing makes it change back.
2017-8-29
Spaners
Flight distance : 1542 ft
I hope this is sorted, I just went and sold my to android tablets and bought an Ipad mini because the android devices I had would not work with the 5G8 channels that the spark uses
I haven't tried the app on the Ipad mini yet !!!!
I will be proper pi**ed if I still cant use 5G8 as I have now spent over £300 buying tablets
2017-8-30
Matioupi
Flight distance : 922569 ft
the 5.8 GHz channels used by Spark are the 149 to 161. In Europe those channels have been allowed by Europeean regulation only starting from 2014. I don't know when they were allowed by FCC (but they are now)
http://eur-lex.europa.eu/legal-c ... 13D0752&from=EN  (band 61 in annex)
The band is sometimes called "SRD" for short range devices
The implementation deadline by member countries was set to July 1st 2014 but some countries still no allwo them in their actuel "country level" laws also the "european level law" tell they should.
(e.g. in France, those channels are not officially approuved by our national agency yet, it is the same in Great Britain)
the latest version to date of the regulatory database used in linux systems (and android uses them) is :
https://git.kernel.org/pub/scm/l ... tree/db.txt?id=HEAD
and you can check that FR or GB do not have those band allowed. There is no EU code in the database...
In addition some Android device manufacturers did purposely disabled those channels to prevent compatibility issues...
In my setup, I currently use a dedicated blackview BV8000 pro device, and it works goods in both bands.
2017-8-30
djiuser_OaS3Dp0b8P1o
Flight distance : 364554 ft
fansfdcc5ccf Posted at 2017-6-20 08:48
Hi all,
I get more distance using   5.8 Ghz
2020-10-6
