hallmark007
Flight distance : 9812789 ft
The problem with rolling back the firmware first is, let's say old firmware was not giving a warning it was supposed to, then in that case you may be flying around in an area of magnetic interference and an accident waiting to happen, there have been some cases where there was magnetic interference on the ground and it was not picked up by the app, but because compass was then askew once aircraft got in the air it just takes off and crashes.
This is why I advised you to go to another location on 800 and check if you got a warning, then you would be able to eliminate the problem.
I wouldn't be inclined to take magnetic warning lightly if you roll back firmware unless magnetic warning comes up again you will never be sure it's not there. |
