DroneFlying
Flight distance : 10774613 ft
No, if everything seems to otherwise be working normally then I wouldn't worry about it. The firmware upgrade process is unreliable and will sometimes do strange things like that. Most likely the firmware was successfully downloaded on the first attempt but the install failed or hung for some reason, and once you retried it the download portion was skipped because it wasn't necessary. |
