Capo
Flight distance : 178196 ft
fans20b4b055 Posted at 2017-6-21 07:01
Should the drone and RC version numbers be the same? My Current Version in Assistant says 01.01.0203 and the About/ver number on the RC is 01.03.00.00. Should I upgrade the drone to 01.03.0509 to make the compatible or is that necessary. No flying as of yet so no way to know if things would work as is.
I don't think they are exactly the same but close. The DJI app should tell you if they are incompatible. Also, When I upgraded and the RC wasn't matched, the RC blinked between red and green. Once resolved it connected green. Not sure if previous versions did that, but I'm not the only one that saw this with the latest. When I switched to a phone rather then the tablet, it saw the RC was off and updated it. |
