Dashware Problem.
capbat
Flight distance : 54905 ft
Hi All.
First I know that this relates mainly to Dashware, but I can't find anywhere on the web a Forum for Dashware.
Dashware support is sending us to either to their Facebook page wich is inactive or to GoPro support  wich I can't get in touch with.
I understand that the author of Dashware is now with GoPro so Dashware Support is Inactive.
So I revert to here cause I know some of you are using Dashware.
If any of you know where I can get support for Dashware please let me know.
I have downoaded the latest version of dashware v 1.9.1 My older version which I don't have anymore used to work ok.
Now I am on Windows 10 everything is ok except for the Create Video in the File tab.
It used to offer me more than one choice in the Encoder section, I think I was using ffmpeg but it is no longer there, I only have 'Microsoft Media Fundation' now.
When I click Create Video I get the error message Box.
Any one can help. thanks Bat
2017-6-20
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Your original video is 4K?
If 4K video when you rendering it will error.
Try use other video converter to convert your 4K video into 1920x1080 then insert it and rendering again.
I have same issues with 4K video and after converted to 1920x1080 rendering success.
Here is my done video.
2017-6-20
capbat
Nelsonlee Posted at 2017-6-20 07:39
Thanks Nelson
No the video is 1920X1080 I think the problem is after new installation on 64bit system I only have one
encoder Microsoft Media Foundation. I don't have ffmpeg encoder choice anymore. And the error comes from MediaFoudnationMedia!!!???
I don't see your video.
Bat
2017-6-20
Nelsonlee
Malaysia
capbat Posted at 2017-6-20 09:54
Thanks Nelson
I also running Windows 10 x64.
Try change the frame rate or Maybe full uninstall then install it again.
2017-6-21
capbat
Thanks Nelson I have tried that. Uninstalled 2 to 3 times and reinstalled without any differences.
2017-6-28
Elias Lrc
Flight distance : 7963 ft
Hi,
The same thing happened to me
You must add audio to the video and it works with the Microsoft encoder.
2018-1-17
