Ex Machina
Flight distance : 1806362 ft
anthonyb Posted at 2017-6-20 16:29
You sir are a steely eyed missile man. After downgrading to 700 then back up to 800 using the assistant, guess what, AF is back and working fine. Which begs the question why was it failing with the original 800 installation I performed over the air? One thing I also noticed was slight interference when close to the drone if I didn't have airplane mode on.
Anyway, thanks Ex Machina for the advice, worked like a charm.
Glad it helped, it's one of the typical steps support will have you to try before throwing in the towel and asking you to send it in. |
