Aardvark
Flight distance : 384432 ft
Well it's quite clever now, if the compass needs calibration (very unlikely) then it will show compass error and calibration button appears in aircraft Status bar, if no calibration is needed then no error is shown, and the button will not appear.
You should only calibrate compass when advised by DJI Go 4, as stated in the manual. If you do see compass errors, then the first thing to do is move the aircraft away from any potential source of magnetic interference and see if it still reports an error. If no error then it's okay to fly.
You can test this out yourself, with all powered up and connected. If you hold a table spoon (metal not plastic :-) ) beside the bottom of the front left leg as you look at front of aircraft (Or it is on my P4), then you will see a compass error appear in the status bar, and also the 'calibrate' button. Move spoon away and it disappears.
This is a good demonstration of why you need to move aircraft and recheck if any compass errors occur, you don't know what could be buried under your feet (Pipes, cables, demolished steel buildings).
Edit:- At least, that's how it is now. May have been different four months ago (I just realised this was an old post).
