nig_smith
The Vision, Vision Plus, and FC40 defy convention and use 5.8GHz for control and a 2.4GHz WiFi link to stream video back to the smart device from the proprietary cameras. The Phantom 2 uses the same system as your Phantom 1. If you want reliable FPV you will need to fit a separate analog video transmitter, usually on 5.8GHz, and use a separate monitor or goggles. Some screens and most goggles have the 5.8GHz receiver built in. Be careful when choosing a 5.8GHz setup as there are some differences between manufacturers. The Immersion RC, or Fatshark, use 8 Channels on one segment of 5.8GHz and the older Boscam system uses 8 channels on a different segment. The newer Boscam and Skyzone have a 32 Channel capability with some cross manufacturer capability.
What you experienced with your Phantom is commonly known as co-channel interference. This is when two devices use the same frequency allocation and interfere with one another. It is possible to have two systems operating at the same time, such as a regular 2.4GHz control from the transmitter and the 2.4GHz Groundstation but these use a technology known as frequency hopping, or Direct Sequence Spread Spectrum, where the carrier jumps to a clean channel many times a second within the allocation. A WiFi signal occupies a relatively large bandwidth on a fixed channel and therefore, when your Phantom is some distance away, will block the signals from your transmitter causing in your case, and very luckily, the Return To Home to kick in.
Regards
Nidge
