Unable to update AC
741 8 2017-6-20
Zadde
Sweden
Hi DJI and everyone,
I have a problem with updating the aircraft with the latest firmware (.0800). I have tried both OTA directly from the app numerous times as well as via DJI Assistant 2 on my PC.
The controller is on the latest firmware (checked with DJI Assistant 2).
I have managed to get to .0550 but any further seems undoable. Update keeps failing. Error LOG is reported.
I am wondering, what is the solution to this?
Best regards,
Z
2017-6-20
Jenee 2
Flight distance : 7852129 ft
When you are using Assistant 2 to do the update, at what point does it fail?
Sometimes it can fail when the Mavic has to do a restart and the PC does not recognise that it has restarted. Usually due to drivers not being installed.
2017-6-20
Zadde
Sweden
Jenee 2 Posted at 2017-6-20 21:56
Hello and thanks for the response!
It fails at 54% when using the DJI Assistant 2 and at 74% when using the DJI Go 4 APP.
I believe it has nothing to do with drivers as the .0550 went through successfully...
I read somewhere that others have experienced this and DJI appear to have some "fix-firmware" to get past this...
Best regards,
2017-6-20
Jenee 2
Zadde Posted at 2017-6-20 22:49
OK. If that is the case then I think you may need to go back to an older firmware like 0.0350 but you would probably need to contact support to get the older firmware. I think that DJI Mindy has helped others in the past.
2017-6-20
DJI Thor
Flight distance : 13602 ft
Zadde, could you please provide me the error code and your DJI account email so we can check it?
2017-6-21
Zadde
Sweden
DJI Thor Posted at 2017-6-21 04:41
DJI Thor,
absolutely. Error code "undefined 0x020106"
zaddedrone@gmail.com
I uploaded error log again just now.
2017-6-21
Zadde Posted at 2017-6-21 12:35
DJI Thor,
Sorry for the inconvenience, please refer to the steps below to upgrade it via the DJI Assistant 2 again.
1. Log into your DJI account.
2.Upgrade the firmware V01.03.0350.
3. Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest version, it will be working.
2017-6-21
Zadde
Sweden
DJI Mindy Posted at 2017-6-21 22:10
Thank you DJI Mindy,
I am not going to speculate further regarding the procedure but my issue is hereby resolved.
BR
Johan
2017-6-25
Zadde Posted at 2017-6-25 22:19
Glad to hear that, enjoy flying.
2017-6-25
