DJI-Jamie
Flight distance : 112405 ft
If you bought the Mavic's DJI Care Refresh in Australia, then you will have to send it to the DJI AU facility in order to use it. When the aircraft is evaluated by the repair technician, you will get the option to either pay the repair or use one of your DJI Care Refresh replacements. At that point you can weigh your option once you see what the repair cost would be. As far as cherry picking parts on the repair invoice, that may be possible depending on what they find is actually detrimental to the aircraft and what is just cosmetic. You would need to work with Support if/when that's applicable. If you aren't planning to really use the DJI Care replacement or want to go through the DJI AU facility, then you would want to look at the following link for alternative service centers that will not jeopordize your DJI Care Refresh by using them:
http://www.dji.com/service/repair/centers
From what I see, EE Hobbies would be the only other alternative within Australia. Keep in mind that the DJI AU Center can potentially help with shipping as well.
