Follo3me
Lowdspeaker Posted at 2017-6-22 09:00
These are great shots but you might want to try lowering your sharpness by 1 or 2 points in camera settings. These will allow for a much more real and cinematic look. You should also try shooting in a shutter speed exactly double that of your video fps, (if 30fps then 1/60 shutter speed, if 24fps then 1/48-50, if 60fps then 1/120).
This can be hard to do even with the P4P's adjustable aperture in really bright conditions. That's when ND filters come in handy to help you stop down your shutter speed for smooth buttery shots!
Thank you. I learnt much more from your post. These suggestions are new to me.
I want to know if your recommendations applicable with using ND8/16 filter, without using ND filters, or regardless of whether I'm using ND filters? Assuming that I'm in the really bright environment.
Thanks again. |
