Xavier1984
Flight distance : 1634843 ft
Switzerland
fansf0a71f5b Posted at 2017-6-23 05:36
HI,
got the same message after update.
to my understanding, it could mean that the wheel has 2 functions. when you push it, it toggles between 2 different image settings, that you can the adjust by turning the wheel
Yep,
If you press on the wheel it change the mode (aperture, time, iso etc..) and you adjust the current mode with the wheel.
But nobody know if the message inform the user that the setting is locked (you need to press again on the wheel to re-select the mode) or if this is another warning message.
