theobslhc
Hi, *bump*
I am experiencing a similar problem on a Matrice 100 with the Guidance system.
My Guidance system and sensors are mounted in standard positions and configured and calibrated properly according to the user manual. The Guidance is connected to the M100 with the provided cable from the 5-pin 'sync' port of the Guidance Core to one of the CAN1 ports on the platform (both tested).
When turned on, the LEDs of the core unit and of each sensors are green and not blinking.
Note that I have also tested the system through the SDK with a UART connection from the core to a computer, and that the data is streaming correctly and appears to be correct.
Still, in a standard setting I cannot find any option on the DJI Go app to 'enable' the Guidance, although I have read several times on this forum that it is a necessary step.
When flying with the Guidance in a GPS-denied setting, the drone is constantly drifting, even over richly-texture surfaces, and the obstacle-sensing feature does not seem to be working.
Could anybody help?
Many thanks |
