New firmware for Osmo is available. (22/06/2017)
10033 10 2017-6-22
DJI Support
Flight distance : 2408 ft
OSMO Release Notes
  • Date: 2017.06.22
  • Firmware Version: v1.10.2.60
  • DJI GO App iOS Version: v3.1.11
  • DJI GO App Android Version: v3.1.5
Major Updates:
  • Fixed an issue where Micro SD card video files could be overwritten in some cases.
  • Fixed an issue where the gimbal could slightly drift when pressing and holding the screen to move the camera.
  • Optimized the D-Log color profile to extend the dynamic range, enhancing the details in dark areas.
  • Improved the gimbal stabilization when taking time-lapses.
Notes:
Auto calibrate the gimbal after restarting. If the firmware upgrade fails, restart the Osmo and the DJI GO app and retry.
2017-6-22
fans5118d392
After applying this update I have been having issues with my Osmo.  I typically film 40-50 clips that are 15-30 seconds in length (4k 24fps).  After upgrading to 10.2.60 I will end up with several of my clips only 2meg in size of completely empty.  This has occurred to as many as 20% of the files.  Prior to the upgrade I had everything work just fine.
2017-7-12
Ariel.Britos
Argentina
para el mobile tambien ?
2017-7-14
lazintech
Romania
fans5118d392 Posted at 2017-7-12 11:24
Hy,
A same problem.
A make some videos, and some files .mov cannot played!!!
How can repair it????
2017-7-15
georgia drone p
I'm having the same issue its does not play back everything I recorded Is there a fix to this or go back to the old software
2017-7-15
fans5118d392
I went back to the previous firmware (1.8.2.40) and have had zero issues.  I have been out twice now filming and have filmed over 100 clips with no issues.  When I was on 1.10.2.60 I would have had numerous clips that were unusable and unrecoverable.  Something is wrong with 1.10.2.60 and DJI should either fix it or remove it from their site so people don't download it.
2017-7-17
djiuser_rfy0Llx
Indonesia
fans5118d392 Posted at 2017-7-17 04:23
How to go back to the previous firmware version from v1.10.26?
2017-10-26
djiuser_rfy0Llx Posted at 2017-10-26 03:37
Please try to download the previous version firmware from our website to SD card and update according to the tutorial video below, thanks.
2017-10-27
fansfc22705b
Poland
Thank you for the hint, with a long trip 30% of movies disappeared just this way, and DJI does nothing about it. It is a scandal in serving customers.
2018-1-3
fansfc22705b
Poland
Will DJI finally specify the deadline for correcting their error?
2018-1-3
fansfc22705b
Poland
Will DJI finally specify the deadline for correcting their error in version 1.10.2.60?
2018-1-3
