fans2b8b0ab6
Flight distance : 734669 ft
The flights have been synced. Account: hborchids@earthlink.net
Date of incident- 6/22/17
Time: 10:35 am at 5 minutes 11 seconds into the flight.
At that time in the flight I received a critical low battery alarm, motor overload warning, motor idling (loose or missing prop) warning. I inspected the aircraft and no problems were apparent. Only the last warning shows up in the flight record. If you look at the max elevation for this flight it shows 2,670 ft. which is clearly wrong since I did exceed 200 ft elevation for any of the flights on that day. It looks to me that the aircraft just had a brain fart. |
