Bandit 287
Flight distance : 439948 ft
Soon after I received by Mavic Pro, I set up a custom configuration so that back on the right stick is up, right on right stick is right turn to mimic an airplane controls, because Mode 2 was counterintuitive for me. I had trouble setting up the configuration initially and had to set up climb and descent the opposite of what I wanted to get the desired effect (i.e., back right stick is down gets me up). It was not an easy task; I just kept fumbling around until I got the desired configuration.
Anyway, two days ago, after I was messing with Litchi, my custom configuration no longer works as it should. For a while, both fore/aft and up/down were opposite what I expected. I have calibrated the controller, reloaded firmware 900, etc. with no luck. The only thing that got close was setting up the left stick the way I wanted the right stick and vice versa. The problem is I want up/down turn left/right on the right stick, not the left.
I am saving after I make changes. Can you tell me what I'm doing wrong?
Thanks
Getch
