DJI CrystalSky & Spark
3620 18 2017-6-23
Tviscomi
Flight distance : 106886 ft
Now that the CrystalSky is available...what do you think the chances are that it'll funtion properly with the Spark?
2017-6-23
DJI-Mark
Perhaps once the product is out for a little while. However, it may be too big for the Spark remote at this time.
2017-6-23
Tviscomi
DJI-Mark Posted at 2017-6-23 07:38
Apart from it not fitting in the remote...would anything else hinder it from functioning with the Spark?
2017-6-23
Nikon 1
I'd be overjoyed if the Bigger / Brighter CrystalSky was Mavic compatible.
Sorry to hijack your thread.
2017-6-23
Tviscomi
Nikon 1 Posted at 2017-6-23 07:40
Yeah, that would be better suited for the Mavic forum.  I like to keep these guys (Moderators) focused on one topic at a time.
2017-6-23
fansd2b11e6f
Flight distance : 394626 ft
United Arab Emirates
I suspect that the CrystalSky would work with the Spark directly over WiFi, such that it replaces the smartphone. My recent experience using the Spark with my iPhone 6 Plus in daylight has not been positive - the iPhone display almost completely washes out, and the device heats up very quickly, which is why I'm looking into getting a CrystalSky display for use with my Mavic and Spark.
In theory, it should be compatible with the RC, since all it does is function as a display. However, I am not sure about internet connectivity since there isn't an onboard GSM/4G radio - tethering to a mobile phone for connectivity might be one option, but if the WiFi channel is in use with one device, I am not sure how it could/would connect to the Spark RC except over a direct/wired connection
2017-6-27
SidneyW
Been using CrystalSky, RC and Spark via WiFi without any issue.  Can't get CS connect to RC using OTG and bypass WiFi.
2017-8-5
Floyd-Spark
Flight distance : 52644 ft
Hi Sidney, I have the same setup as you. I am using the Mavic mount for the CS to my Spark as suggested by DJI here in Hong Kong. I am unable to plug a cable into my Spark RC because of where the mount cable is positioned. Also when I used my iPhone via OTG to my Spark I could get to about 100m high before transmisson issues, using CS via wifi to RC I encounter transmission issues before reaching 50m. The CS is awesome though.
2017-10-8
Jefferey Drone
Flight distance : 48465 ft
I have my 7.8 ultra so I can switch it from the phantom to the Ma...
it will fit the spark remote just fine just use the Mav mount.
I have my CS 7.8 ultra to switch from my P4P to my Mavic and now to the Spark  :-)
2017-12-20
nixuspix
Flight distance : 2864974 ft
Latvia
Floyd-Spark Posted at 2017-10-8 17:34
You can use just simple micro usb to micro usb otg cable and connect micro usb port of CS on the side with micro usb port of RC. The usb-C port becomes disabled at that time
2017-12-20
Wachtberger
Flight distance : 261509 ft
SidneyW Posted at 2017-8-5 09:31
For me it worked well with OTG (connected to the C Port at the bottom of CS) until we got the GO4 version .18 with the recent update. But this will hopefully be fixed soon. Until then I have to use WiFi which also works well.
2017-12-20
JMR58
Flight distance : 627966 ft
Belgium
Jefferey Drone  Posted at 2017-12-20 07:06
The CS 7.8 with Mav mount on Spark RC is very unconfortable, if you hold the CS you almost can' t reach the sticks and if you hold it by the RC itself it is completely out of balance.
Holding the combination between doesn't feel safe..
2017-12-20
nixuspix
Latvia
Wachtberger Posted at 2017-12-20 08:03
His problem is caused by using DJI mount bracket as i got it, but maybe i am wrong
2017-12-20
Wachtberger
nixuspix Posted at 2017-12-20 08:44
The DJI mount bracket does not have an OTG cable, it's normal USB. An OTG adapter has to be added to it.
2017-12-20
nixuspix
Latvia
Wachtberger Posted at 2017-12-20 08:47
That's right, but the guy couldn't find appropriate one OTG ( it really has to be a very special) , so i only suggested the replacement, which will work
2017-12-20
Wachtberger
nixuspix Posted at 2017-12-20 09:23
Ah now I understand the problem, it's about the horizontal mount that makes holding both RC and CS uncomfortable. I am using this mount for the CS and it is perfect for my wishes:
2017-12-20
JMR58
Belgium
Wachtberger Posted at 2017-12-20 09:32
Ah now I understand the problem, it's about the horizontal mount that makes holding both RC and CS uncomfortable. I am using this mount for the CS and it is perfect:
I am using this combination also (Thanks Wachtberger for the order link), and it is much more comfortable with the Spark RC than the CS Mavic mount!Just have to do some easy screwing when you switch to official DJi mount on Phantom controller.
2017-12-20
Wachtberger
JMR58 Posted at 2017-12-20 11:43
Glad to hear that I have not "lured" you into a purchase that you would regret :-)
2017-12-20
JMR58
Belgium
Wachtberger Posted at 2017-12-20 12:32
Not at all!!, Thanks for your input
2017-12-20
