Inspire 2 HDMI issues with downloadable dropbox file
3849 23 2017-6-23
Ale Reynoso Cin
Argentina
Hi:
We are having issues with the HDMI output of the Inspire 2
I made a test and uploaded it to dropbox.
ASAP the same video in youtube and vimeo, but I doubt it can be noticed there
[url=https://www.dropbox.com/s/98pdbx ... %202%20hdv.mov?dl=0]https://www.dropbox.com/s/98pdbxeqp6kfmm5/test%20hdmi%20inspire%202%20hdv.mov?dl=0[/url]
250 Mb aprox.
I´ll be waiting your comments! As far as I know every i2 could be suffering from this (it´s just you did not noticed it)
Best regards
Alejandro
2017-6-23
Ale Reynoso Cin
Argentina
Can DJI do something? banned as "unusable" by the OB truck engineers...
2017-6-23
Ale Reynoso Cin
Argentina
Tested every setup combination. Always there. Seems to be a big variation on the bitrate that shows in the picture.
2017-6-23
Ale Reynoso Cin
Argentina
2017-6-23
Ale Reynoso Cin
Argentina
2017-6-23
elmago
Flight distance : 40663 ft
Argentina
why there is not even a comment of DJI??
2017-6-26
DTK
Flight distance : 1943159 ft
Any follow up with this issue? Wonder it will be resolved given that DJI is in the forefront of aerial videography game.
2017-6-26
elmago
Argentina
Could the new firmware get a solution on this ??
it says
 Optimized image signal quality in some countries and regions.
2017-6-27
Live Tv
Flight distance : 8104 ft
elmago Posted at 2017-6-27 07:16
it says
Seems to be an improvement , still a cycle refresh but only really noticeable in low light when the aputure  is open wide ...     more testing required but seems to have changed for the better
2017-7-2
May I have more details of the question you've showed in the video? You mean the exposure isn't steady and there is something like noises keep flashing once a second? HDMI output transfers the image through wireless, the quality will be compressed, when the sharpness is added, many invisible things will show up.
Please forgive me that I didn't find out the issue you want to convey from the video, We would be highly appreciated if you could provide more details.
2017-7-3
Ale Reynoso Cin
Argentina
DJI Mindy Posted at 2017-7-3 00:55
May I have more details of the question you've showed in the video? You mean the exposure isn't steady and there is something like noises keep flashing once a second? HDMI output transfers the image through wireless, the quality will be compressed, when the sharpness is added, many invisible things will be show up.
I added sharpness to the edited video to watch what in fact it is subtle in the transmitted image.
There is no issue with exposure. I know the compression fact. What is annoying and makes the issue noticeable is that there is some kind of "refresh" in the compression (scrolling up-down) that shows clearly. Normally, with regular images, no sharpness added, you can notice it scrolling down (this "compression scroll refresh"). In some other moments could be disguised.
This issue made the engineers at the OB truck (from a major broadcast company) say it was unusable. We lost the job opportunity and our DJI representative has not received a word about this (he opened a case with all the details. Even this video).
Several forum user said they never had an issue like this in their i2
But every i2 we tested here (Argentina) shows this
2017-7-7
Ale Reynoso Cin
Argentina
So you did not found anything irregular in the video?
The "compression scan bar" going down?
It has nothing to do with exposure. It´s a compression artifact that seems to affect the sharpness  with this up-down pattern.
2017-7-7
Ale Reynoso Cin
Argentina
Ale Reynoso Cin Posted at 2017-7-7 02:14
Watch the DJI shop shot i.e.
If you look at the Phantom boxes at the top, you can clearly see them pulsing. This is with the sharpness enhanced and just to make noticeable in the video I uploaded. But with live view, HDMI connected in a big monitor, even with sharpness from the camera dialed down, you can see this pulsing in the image
2017-7-7
Ale Reynoso Cin
Argentina
Ale Reynoso Cin Posted at 2017-7-7 02:21
So?
Any comment? I made it as clear as I could, but you see the issue in the video
2017-7-10
Ale Reynoso Cin
Argentina
Ale Reynoso Cin Posted at 2017-7-10 10:38
So?
DJI Mindy?
2017-7-13
I’m sorry that I fail to reply your message in time because of holiday. Our engineer is still analyzing, I will keep you updated once I hear from them, appreciate your patience.
2017-7-17
Ale Reynoso Cin
Argentina
DJI Mindy Posted at 2017-7-17 01:58
Thanks
This is the firts time I know from DJI that they´re analyzing the issue
Good luck with that and I hope it doesn´t take too much time to solve it!
2017-7-17
DJI_camera
Hi Ale,
This is a software issue caused by the encoding method of the liveview data. We are still exploring solution. Sorry for your waiting. And thanks a lot for your feedback.
2017-7-27
fansf7f1ef8e
Flight distance : 3228383 ft
Argentina
charlesetischer Posted at 2017-7-27 22:01
Hi Ale,
Hi
I hope you to solve it soon
We are still loosing job opportunities regarding live feed. We keep testing. Some times you barely note it, but sometimes it is so bad you can see it even in the ipad small screen
Thanks
2017-7-29
Papaxiclas
Flight distance : 5455981 ft
Portugal
Hello,
Half year later and I got caught with this issue also.
Have you found a solution for this or the Inspire 2 simple can not be used for broadcast jobs?
Thanks
2018-1-17
wingthing
Flight distance : 1866204 ft
Is there any solution to this problem? It is end of April and no one postedsince january. I still have this problem. Also on cendence with SDI-
2018-4-30
Airking Pilot
Argentina
wingthing Posted at 2018-4-30 17:20
From DJI:
I  think it´s a design fact, so cannot be easyly reversed/corrected.
Sometimes you cannot even notice it. Sometimes it clearly shows.
2018-5-2
mixchief
Flight distance : 182057 ft
I actually noticed the exact same thing on a video posted elsewhere in this forum a day or two ago, just don't remember which. I chalked it up to connection issues on my end so I made no comments, but it is very evident it's your same issue.
2018-5-3
tim92
Flight distance : 105338 ft
I've just spent a couple of days trying out both broadcast mode through HDMI to an Atomos recorder, and Streaming to Youtube - Inspire 2 with X5S. Tried every combination of settings possible. Unable to get a signal that's remotely useable. The compression artifacts and dropouts make these modes useless for broadcast applications. I am abandoning this project. I don't have an axe to grind, because otherwise I think this bird and camera shooting raw and recording onboard to SSD is the best thing since sliced bread.
2018-7-8
