Nigel_
Flight distance : 388642 ft
Kwalter Posted at 2017-6-24 08:18
Thanks Nigel, you were spot on. It was obstacle avoidance
I've also set up my iPhone for local wifi access, so hopefully next time I can self certify, regardless of the map discrepancies
Good luck, I don't see why you have a problem in that area, like you say it appears to be green and should just need the warning acknowledged, although you are only 2.5 miles from an airfield and not far from Gatwick so fly carefully and make sure you stay within the Drone Code rules, be ready to give way to manned aircraft, and treat the first few flights as test flights - don't fly over people and keep it above head height. I suggest you only enable the internet connection for as long as is needed unless you have unlimited data.
