Phantom 4 Pro - fix request for future FW update
1030 11 2017-6-24
Drobo
Flight distance : 1090961 ft
Please prevent the drone defaulting all my custom photo and video settings when going in and out of Active-track mode
This has to be the only real gripe I have with the P4P so far
Cheers!
2017-6-24
Rodger8
Flight distance : 20145135 ft
You should check all of your settings after an update, as some of them return to default.
2017-6-24
Drobo
Rodger8 Posted at 2017-6-24 05:34
No, this happens after selecting 'Active-track' mode
2017-6-24
Rodger8
Drobo Posted at 2017-6-24 05:36
I have never used that so, I couldn't say that is or is not the norm.
2017-6-25
Antonio76
Flight distance : 144403 ft
Denmark
Have you asked Ty?
2017-6-25
Drobo
Rodger8 Posted at 2017-6-25 03:00
Maybe you should try it then...
2017-6-25
Rodger8
Drobo Posted at 2017-6-25 16:08
I'll give it a go next time out
2017-6-28
theGrindLab.com
Flight distance : 1375846 ft
If that is the norm, it really should not be. If switching flight modes clears your custom settings in other modes, that is a poor design.
2017-6-28
Drobo
What is happening is the drone is (probably quite rightly) switching into full auto-mode on the camera for the Active-track function, this then allows the camera to easily pick up and track the subject, but sadly when going back into normal non-Active-track mode, those auto settings are remaining
Which means if you do use Active-track in a session you have labouriously re-set all your settings again, RAW, 4K60fps, manual mode etc etc, before you can continue, which wastes a lot of time in the air, or if you forget... a folder full of JPGs
Really needs to be fixed IMO
2017-6-28
P4P+
Drobo Posted at 2017-6-28 20:57
Yup, it is a bug that has been there since the release of the P4P. I don't know what is taking DJI so long to fix it. The video changes to 4k 30 even though 1080P 60 was slelected, for example. The work around is change the setting back manually after active track changed it.
2017-6-28
fansc629d008
Banned
2017-6-30
Drobo
Thanks for that input, but can we please remain on topic?
2017-6-30
