Active tracking elevation change
1444 10 2017-6-25
Callatis
Flight distance : 511112 ft
Hi,
I started using Active Tracking following my boat and this is the second time when the P4 is gaining altitude as she cannot keep up with the boat speed.
The P4 was at about 12-15m in the air and by the end of the clip it was at 50m.
The boat speed didn't exceed 38Km\h. At 1:20min I started pushing right the stick to orbit around the boat and you see how behind the P4 remains.
Am I doing something wrong? I need your advise.
Thanks
2017-6-25
DroPro
Flight distance : 1134285 ft
You flew towards the sun, that doesn't work. You want to have the sun in your back.
2017-7-1
Callatis
DroPro Posted at 2017-7-1 04:46
Thanks for your tip. I'll try next time. During that ride Active Tracking didn't loose me, I had the green square around the boat.
One other time, the same behaviour on a  cloudy day. The P4 was tracking me and it gained altitude. Then I stopped for fishing, I had the drone 5m above and lateral to us and again it went to a higher altitude.
As recommended by others I did the IMU and Compas calibration one more time and I'll check active tracking next time I'll be on the water.
2017-7-2
MrPinaColada
Flight distance : 790082 ft
Callatis Posted at 2017-7-2 05:33
Did you have the vps enabled? When flying over water the vps can get confused and cause variations in hovering and height
2017-7-2
Callatis
Well, I went again yesterday, I made sure I wasn't flying against the sun, VPS was disabled and the drone was hovering at 5m above the water. I activated the Active Tracking and I started driving my boat. I went to  18Km\h and I saw how the drone was slowly slowly gaining altitude. All this time I was in the center of the screen, the drone was high in the sky and way behind me. Video will follow.
When I got the drone I was following all sorts of tutorials and I think I maxed the speed of the drone to 5m\s which is 18Km\h. Also I played with some of the settings so the drone won't accelerate hard, to have a smooth motion.
I believe as the drone can't keep up with my speed it will ascend in order to keep me on the middle of the scene. Probably for my next test I'll factory reset the DJI GO 4 app.
2017-7-4
Callatis
2017-7-5
MrPinaColada
What's interesting is the gimbal is not pitching up or down, when I used to fly my p3s the gimbal would pitch up for it to keep me in the shot however I don't have enough experience with active track on the p4. Will most likely try tomorrow and let you know if it also gains altitude.
2017-7-6
SomeoneElsesDro
Flight distance : 419669 ft
What are you using to run the app? Have you tried a different - maybe more powerful - mobile device? Much of that processing is happening on the fly using your device - might be worth a shot. Also worth trying autopilot or litchi - see if behaviour changes. Doesn't look normal.
2017-7-7
Aardvark
Flight distance : 384432 ft
Could be a whole new game with the latest P4 updates, would be interesting to see if any improvement.
2017-7-7
Callatis
SomeoneElsesDro Posted at 2017-7-7 14:13
I use an iPAD 2. I didn't try any other device. I have a Lenovo TAB2 but I noticed the DJI GO wasn't configured for that screen. I never tried the DJI GO 4 on it. But thanks for the tip!I don't have the other apps but Litchi is on my list. I want Litchi for the waypoints mission. The new firmware 30-50m rule will affect Litchi?
2017-7-8
Callatis
Aardvark Posted at 2017-7-7 14:44
Yes, running Active Track using the Profiles modes might be a game changer. It's windy today, so next weekend if the weather allows I'll try it.
2017-7-8
