Choppy Video in iMovie
35013 17 2017-6-25
fans4fc4da16
The videos transferred from SDcard play smoothly in QuickTime Player and VLC.  However when I use the videos in iMovie or Final Cut Pro,  it is choppy.  The rendered video is also choppy when played on any device.  The output format is the same as the DJI recording format 1080p 29.97 fps.   Anyone else notice this issue?
2017-6-25
J.Randeris
Flight distance : 230443 ft
Denmark
Think you import in 24 fps, try 30 fps .....
2017-6-25
pvtsailor
Flight distance : 675709 ft
I hope that's the reason. I'm only using imovie (IOS) for Video.
2017-6-26
fans4fc4da16
Hi, thank you for the suggestion.
How do you tell iMovie to import at 24fps?   I didn't see an option for it.  It seems to automatically detect frame rate.  My other videos from iPhone and Canon cameras don't have this problem.  I am using 1080p, 30fps, H.264 across the board.  Is there something peculiar about DJI movies?
If there was a sample DJI Spark video I could download,  I can check whether it is an issue with my drone or with software/computer (although I am having same issue on multiple computers).  Plays fine in VLC,  but becomes jerky as soon as it is imported in an editing software.
2017-6-26
fans4fc4da16
UPDATE:  I figured out that while importing video clips in Final Cut Pro,  if you change the default frame-rate of 29.97 to 30fps,  the video plays smoothly.   Using the 'mediainfo' utility,  the only difference I see between DJI videos and videos from other cameras is the following:
DJI:          Frame rate                               : 29.970 (30000/1001) fps
iPhone:     Frame rate                               : 30.000 FPS
So the question is whether DJI is reporting the frame rate incorrectly in its files or it a software issue on the desktop?   As it stands right now,  I can't edit videos in Filmora or iMovie.  But I am able to get past the problem by manually changing frame rate in Final Cut Pro.
2017-6-26
chraaaa
Flight distance : 114377 ft
I'm having this issue with importing my first Spark video into iMovie.  Spark shoots video at 30fps, and I imported into iMovie at 30fps.  But viewing the original video in Quicktime it is nice and smooth, the same video in iMovie is choppy and juddery.  I'm using iMovie 9 which is the older version.  I will try on iMovie 10 but I don't believe that is the problem.  Any suggestions?
2017-7-3
wamike
chraaaa Posted at 2017-7-3 05:42
I'm using iMovie 11. Same problem! Video looks fine in QuickTime but very choppy and blurry when imported into iMovie {:4_154:}
2017-7-4
dojoman
Flight distance : 64865 ft
You can fix choppy videos in iMovie by trimming a few seconds of the clip in media before putting it in timeline. Somehow that fixes it.
2017-7-31
JMX46
Flight distance : 101220 ft
dojoman Posted at 2017-7-31 08:20
This works !   (trimming a few seconds off the clip) - thanks - great tip
note - looks like you have to trim off the Front of the clip not the end for this to work
- you can also use a 3rd party clip editor or trimmer and get the same result (but takes a bit longer)
2017-8-29
Rawsome
Flight distance : 230827 ft
Great tips!
2017-8-29
dojoman
JMX46 Posted at 2017-8-29 05:28
I didn't know you have to clip in the beginning. Anyway, I'm using Final Cut Pro now it doesn't have this issue if 30fps timeline was used. I hope Apple fix this for iMovie.
2017-8-29
Montfrooij
Flight distance : 2560453 ft
iMovie indeed runs on their own native fps.
Bummer for footage that was not shot on iPhone.
2017-8-29
Gr33n13
Flight distance : 30935 ft
Is there anyone perhaps that can tell the difference between footage shot on Iphone and Android (footage at the same time) or that footage is more smooth on Iphone instead of Android.
2017-9-11
Sparky_17
Flight distance : 62349 ft
This is good to know.  I was just about to purchase Final Cut Pro X but was holding off until someone could figure out how to get the jidder out of the video.  Seems like you change the import default to 30fps and all is good.
2017-9-11
LOKY
Flight distance : 22359 ft
Sparky_17 Posted at 2017-9-11 05:06
Try Davinci 14 , is free and do the same work. Also, converting SPARK clips to 29.97 can be easily done with Adobe Media Encoder or WoinderShare
2017-9-11
Gr33n13
Srry for my messsage a day ago about the choppy video in imovie.... i always used the video items on my mobile phone with imovie, but as a beginner NOOB (as i say soo of my self :-)) I now just the video recordings on the SD-card in the AC itself and woooooow... what a nice scenes
So again sorry for the message, and now for some more flights...... keep up the flights
2017-9-12
Montfrooij
Gr33n13 Posted at 2017-9-12 05:47
Good to know you figured it out!
Love to see some shots
2017-9-12
fansdf7d83d7
To start with, use this file type identifier - https://www.filetypeadvisor.com/ . It will precisely identify the file type as well as recommend you a player to use. Hope it helps
2017-9-26
