DJI Go App Thinks I have a Phantom 3 Standard.. NOT!
1432 12 2017-6-25
fans4d9f2ecb
Been using DJI GO App with my OSMO+ for sometime, but had issues connecting today with my iPhone so after hours of trying to debug connectivity, I reinstalled the Go App on the iPhone.
Now the App is stuck thinking I have a Phantom 3 Standard not an OSMO+ when I connect to the OSMO+ wifi!
If I disconnect wifi, the Go App lets me choose from the various DJI devices as it should. But if I then connect to the OSMO+ wifi it reverts back to Phantom 3 Standard.
SO FRUSTRATING!
I can still connect to the OSMO+ with the DJI Go App on my iPad and all is fine.
Uninstall the app a million times on the iPhone and no go.
Any ideas??
Thanks
2017-6-25
CampADK
I should note that I can see the camera view on the OSMO, however the viewer is setup thinking my OSMO is a drone. No controls on the sceen work, but I can see what the OSMO+ camera sees so yes the DJI Go App is connect to the OSMO+, its not a connectivity issue.
2017-6-25
Please reset WI-FI via the following method: before powering on, keep pressing the Trigger and Shutter button at the same time, then press Power switch for about 8 seconds, when the right indicator becomes solid green, release them, search Osmo+ WI-FI and input password again. Please keep us updated if it works, thank you.
2017-6-26
CampADK
DJI Mindy Posted at 2017-6-26 01:02
Hi Mindy,
Odd that would work as it was able to see the camera before, but it worked!
Thanks!
2017-6-26
CampADK Posted at 2017-6-26 03:09
Hi Mindy,
It's good to know, please keep me updated if there is further problem.
2017-6-26
Stéphane_59
Hello ! I have the same problem but the solution don't work
(with an android it's ok)
2017-7-6
Stéphane_59
Stéphane_59 Posted at 2017-7-6 13:11
on iPad it's ok
2017-7-6
Did you also install the DJI Go 4 APP? The DJI Go 4 APP must be closed completely when you run DJI Go.
2017-7-7
milovp
Hello, I was having the exact same issue and I may have figured out how to resolve it.  I had my phone plugged in to power all the times that I was trying to get it to sync with the OSMO and I kept getting the Phantom 3 Standard connection.  Once I unplugged my phone it recognized the Osmo and connected without issue.  Try plugging it in while connected to the DJI Go app and disconnect and see if that makes a difference.  I also completely reset my phone before doing so.  It could have been a combination of both.  Good luck!
2017-7-15
Ramon Bueno
Brazil
Hello
Im having the same problem and reset the wi-fi does not worked. I also tried to do the thing with the phone pluged and unplugged but no results .
My OSMO is recognized like DJI Phantom 3 Standard.
I think that can be a firmeware problem.
I dont know what to do    =/
2017-7-16
待疯狂的渣渣
Flight distance : 61214 ft
China
Ramon Bueno Posted at 2017-7-16 17:34
Hello
did u have your dji go 4 app installed on your device?  and go 4 must be closed when using go3.
2017-7-16
Ramon Bueno
Brazil
Tip: The post by the administrator or moderators shield
2017-7-17
Ramon Bueno
Brazil
I dont have DJI GO 4 installed on my device
2017-7-17
