"Map Loading" where the Location used to be
1949 15 2017-6-26
W.T. Foxtrot
Flight distance : 1316732 ft
Ever since I installed the latest DJIGo update, I am not getting the name of the location in the Flight Record log.   GPS signals are fine before and during flight, and the maps are visible both during and in the log.  But the names (which used to come up correctly) never load into the log.  Have tried using both my iPad Mini4 and my iPhone 7+. Could this be related to the switch in maps that DJI is now using?  This is not good.....
2017-6-26
Heavysledz
Flight distance : 819491 ft
I just checked my flight logs and my flights from Sunday all have location names assigned and I am on the latest firmware and GO4 app rev.....
2017-6-26
Mari
Flight distance : 1308780 ft
... name of location will show up later... it needs some time to load, make sure you have internet connection so app can load the part of the map that is needed.
2017-6-26
W.T. Foxtrot
Mari Posted at 2017-6-26 13:20
Thanks, Mari.  That's what I thought at first too, but I have flights from a week ago that still say that.  I then concluded it must have been a glitch that day.  When I flew this morning, the same thing has happened.  I have LTE and WIFI available where I fly, so a connection is not the problem.
2017-6-26
Jenee 2
Flight distance : 7852129 ft
W.T. Foxtrot Posted at 2017-6-26 13:59
Just tap on one of the flights and it should update the location. Mine always show up as "Loading" and stay that way until I look at one of the flights, then the location will show on all the flights.
2017-6-26
W.T. Foxtrot
Jenee 2 Posted at 2017-6-26 22:18
No luck there either.  This problem started at the same time the DJIGO4 app started crashing in flight...
Have three sets of multiple flights in different locations..... no locations.  The first set is about two weeks old and have been opened multiple times.
2017-6-27
Jenee 2
W.T. Foxtrot Posted at 2017-6-27 03:57
Are you using DJI Go or DJI Go 4?
2017-6-27
W.T. Foxtrot
Jenee 2 Posted at 2017-6-27 22:15
DJI Go 4 (4.1.2)  Just noticed today there is a new version out with  "Bug fixes"  -- Hoping mine is one of the bugs fixed, but I cannot believe they could not have been a little more specific on what they have addressed!
2017-6-28
DJI Thor
Flight distance : 13602 ft
W.T. Foxtrot Posted at 2017-6-28 17:40
Hi Foxtrot, map loading almost relates to the internet. Would you mind uploading your flight record and PM us your email account? Just to verify if it can load in our device.
2017-6-28
W.T. Foxtrot
DJI Thor Posted at 2017-6-28 19:43
Hi Thor,
I have sent you the information.  Thanks
2017-6-29
W.T. Foxtrot
Hi Thor,
It has been almost two months and I have never received a response after I uploaded the flight records.  I guess this is one more problem  that will just get ignored?  Very disappointed that I couldn't even get a "we have no clue" from you.
2017-8-10
DJI Thor
W.T. Foxtrot Posted at 2017-8-10 09:22
Hi Thor,
I am sincerely sorry for this, but I still haven't got the result, I'll push the engineers and escalate it. Thanks for the patience.
2017-8-13
AidanKless
ISO DJI GO fetches location name from server when
1.DJI Go launches.
2.click the flight item and view the flight trace details.
There is no guarantee that the fetch request would succeed since the this request api is provided by apple map or a certain kind of map the ios device is using.
So the current solution for fetching location name is to trigger the request multiple times.
2017-8-15
DJI Thor
Hi Thor,
Hi there, reply on 13# is from our engineer, please check. Thanks for your patience.
2017-8-17
fans143c105d
Flight distance : 141322 ft
Are there any updates on this thread.? Thanks
2017-12-30
W.T. Foxtrot
Sadly no. DJI seems to have blown it off. I have probably 50 Flights with this problem.
2018-2-25
