maxisteve
Flight distance : 51677 ft
Currently DJI has limitations on their Ground Station software that limits setting waypoints anywhere within a 5 mile radius to an airport. I was hoping that may change in the future to be more consistent with how the airport restrictions are set on the Phantom series, i.e. varying altitude limitation based on proximity to airport. For example, if you are 2 miles out, you can still fly your phantom however, the altitute would be limited to around 200 feet or so. I am hoping that there will be a change on the ground station software to match this. You would then be able to set waypoints but would only be limited in the same way as the phantom series multirotors are limited. IF anyone knows of any updates or changes regarding the ground station and airport restrictions, would be great to hear back, thanks.
