RCNJ
Flight distance : 114665 ft
put your ISO to 100 and your shutter on twice your frame rate, so if you are shooting at 30fps your shutter should be at 60 for example
if you cannot get to that in normal light you will need ND filters to assist in stopping light to get your shutter to twice framerate, that is best, the lower the ISO the better, if the ISO goes high the quality is poor etc
also dont use Auto white balance, select sunny or cloudy depending on the day, that helps a bityour EV on the app should ideally be 0 to 0.7 +/- and no higher, or you get overexposure which looks like the 1st image
