Should DJI to replace red 1345LS mountings free?
1445 21 2017-6-28
AEROKAMERA
Flight distance : 2289429 ft
Poland
I can't fly with loose propellers.
2017-6-28
Is it possible to provide a short video for us to check? Please upload it to Dropbox and post the link here at your most convenience, thank you in advance.
2017-6-29
AEROKAMERA
Poland
DJI Mindy Posted at 2017-6-29 01:34
Here You are. I use wetransfer LOOSE_RED_1345LS.zip
2017-7-1
AEROKAMERA Posted at 2017-7-1 23:55
Is there any cracking sound when you rotate the propeller manually? How about changing another propeller?
2017-7-3
AEROKAMERA
Poland
DJI Mindy Posted at 2017-7-3 03:35
Both whites are ok (almost but can fly), both reds not. I temporary use washers prepared by myself
2017-7-5
AEROKAMERA Posted at 2017-7-5 11:37
Is there rattle sound when your rotate the red propellers manually?
2017-7-7
AEROKAMERA
Poland
DJI Mindy Posted at 2017-7-7 01:25
Yes, they are very loose.
2017-7-14
Mike-the-cat
Flight distance : 22488593 ft
Singapore
Newer generation props have a little foam at the bottom. You can easily and I mean easily, alleviate your problem by putting some tape at the base of the prop mounts on the aircraft side.
This said, DJI should just send all registered Inspire 2 owners who have first gen props one of those foam loaded ones to quell a common issue. This issue has been present since day 1 but most of us just live with it.
2017-7-14
AEROKAMERA
Poland
Mike-the-cat Posted at 2017-7-14 20:21
Foams already applied, doesn't help. I use my homemade washers. Is it safe?  Is it ok?
2017-7-15
fansa84fe8a4
Flight distance : 3 ft
I just did the CA Medium glue trick mentioned in another thread around the underside edge and all was well again.
Actually, my P4 blades still are a lot looser than the Inspire 2 loosest blades were.  This could be an overblown case matter, imho.
2017-7-15
Mike-the-cat
Singapore
AEROKAMERA Posted at 2017-7-15 02:03
Anything that tightens up the props works. The problem is gradual erosion of the material on the props as it gets ground down from repeated attachment and removal using the twist lock mechanism.
I think DJI will eventually modify the locking system or the prop material but its been awhile.
This mechanism is very secure so from a safety viewpoint I think we are fine. However, it is annoying and one would expect a little more from DJI.
To be honest, the V2 system from the Inspire 1 - screw down props with add on spring clip IMO is a better option than this mechanism but has the inconvenience of having to use clips and having some heavy handed users overtighten the props.
No perfect solution so I think DJI compromised here.
2017-7-15
AEROKAMERA Posted at 2017-7-14 09:21
The propellers of Inspire 1 are different from Inspire 2, if the propellers are loose and have rattle sound after inserting foam, we suggest to send in your drone and propellers to repair center for evaluation and repair for the sake of flight safety.
2017-7-17
AEROKAMERA
Poland
DJI Mindy Posted at 2017-7-17 04:12
2-3 weks without flying, no thanks, I'd rather back my old mountings.
BTW. Why my whites props (2 pairs) are ok and reds not? Why I need to send whole set of my Inspiere to repair, why not only mountings and props?
Has Inspire 2 different whites and reds props? I think it's nonsense.Look at that:
2017-7-18
fanscf3e31a5
Dji are sending me no mounts and props they assure me this will cure the problem
2017-7-18
RichJ53
Flight distance : 1837356 ft
Mindy
I sent you another PM...
Thank you
Rich
2017-7-18
RichJ53 Posted at 2017-7-18 20:57
Mindy
Rich, I see, have replied.
2017-7-20
AEROKAMERA Posted at 2017-7-18 10:10
We will send 2 red propellers to have a try. Would you please PM me your name, contact number, email address and location? Thank you.
2017-7-20
AEROKAMERA
Poland
DJI Mindy Posted at 2017-7-20 02:38
Many thanks for your help. PM sent.BTW. New 'Fix' for loose red props
2017-7-21
AEROKAMERA Posted at 2017-7-21 07:35
Thanks, we have informed local repair center to send 2 red propellers firstly to have a try. Thanks for the patience.
2017-7-23
KD7CAO
I spoke with DJI Support about this problem at great length via E-Mail and chat. I have not heard a resolution to this, but I like the fact that the Inspire 2 fix seems to be logical. If this is so simple could DJI not just replace our loose locks? I purchased two sets from DJI directly and that would seem very easy to verify. I tried the electrical tape method which worked, but DJI told me it was a modification to the aircraft which causes issues according to my FAA COA. The foam as others reported did nothing but mask the symptoms.
2017-7-27
AEROKAMERA
Poland
DJI Mindy Posted at 2017-7-23 22:46
I received yet nothing.
2017-8-20
AEROKAMERA Posted at 2017-8-20 01:23
I‘m so sorry for this, I have informed local team to send the propellers as soon as possible, appreciate your patience.
2017-8-21
