user2265c2cb1b Posted at 2017-6-29 03:43
Hi,
I have a number of questions. First tho' I would like to understand how the Auto/Manual focus setting on the lens works (as it doesn't seem to be a simple continuous auto focus or manual change) and how that relates to the DJI app and also the focus wheel (does the focus wheel enable/disable or change either function?).
Many thanks,
1. We suggest to select AF button on the lens, then you can choose AF/MF in APP. If you select MF button on the lens, you can only use MF function in APP.
2. When you connect focus wheel to the Osmo Pro, focusing, adjusting aperture can only be operated by turning the wheel rather than APP. This is the difference of enabling focus wheel or not. |
