LSDMT
i have a P4P and had the latest mini iPad. upgraded and had the same issues with video signal.
but i know what the issue is. it is somewhat fixable but does still need to be addressed by DJI:
the latest firmware versions got rid of your ability to control the bit rate of your video feed on ‘auto’ channel select. on ‘auto’ it is now defaulting to 10mbps and you cannot change it. the iPad mini and other lesser-powered phones/tablets cannot process the vid feed fast enough and choke. resulting in choppy or absent video.
the only 2 current workarounds are this: get a faster screen (like ipad pro, iphone 7, etc) OR if you change your video feed (2.4 or 5.8) to MANUAL - it lets you then reduce the bit rate back to 6 or 4mbps. sucks tho, because for longer flight distances - you may fly over an area with a strong signal on the channel you manually chose.
i, too, hope this gets fixed. i ended up going and getting the brand new ipad Pro 10.2” which cost me a lot of money :/ |
