S1000+ top mounting battery
910 3 2017-6-29
ThinAir
Flight distance : 659150 ft
Hi all,
S1000+ is a great flying machine. Having 2 different gimbals (Gremsy H3 and H14 - with extension landing gears) to stack under, I'm wondering if it would be possible to mount a Lipo battery on the top plate of S1000+ ?
So that we can have 2 different gimbal mounts under the body.
Has anyone has ever seen that kind of a set-up ?
Thanks.
2017-6-29
fans92db4c8e
Atulizacion bateria
2017-6-29
fans92db4c8e
Atulizacion bateria
2017-6-29
PeterFDJI3
I have not seen it but don't see why it would not work.  May throw off your Center of Gravity calcs, which you can adjust.  Perhaps two batteries, connected in parallel, so as to distribute the weight evenly if your GPS bracket is in the center.
2017-7-1
