P3 Standard camera tilted?
1021 9 2017-6-29
fans536dd43d
Flight distance : 248983 ft
Hi, I hope someone can help me as I cant seem to find a subject in the forums matching mine, although with so many I may have overlooked it. My problem is that the camera is pointing slightly right (looking back to front of the drone). I have had a couple of beginner crashes although relatively soft (never perform a RTH test under Oak trees!). I have calibrated the IMU, the compass, and the gimbal plus have performed the gimbal centering routine. It still points slightly right, although functions just fine. Any ideas? Thanks in advance.
2017-6-29
DJI Diana
Flight distance : 2408 ft
Could you please post a pic about this issue for better assistance?
2017-6-30
fans536dd43d
I would if I could but do not know how to post the picture?
2017-6-30
fans536dd43d
DJI Diana Posted at 2017-6-30 02:36
2017-6-30
fans536dd43d
2017-6-30
Eric13
Flight distance : 13982031 ft
If you want to upload a picture, click in the top right of the text window on "Advanced".
Then you can upload a pic from your desktop withou being asked for image address.
2017-6-30
fans536dd43d
Eric13 Posted at 2017-6-30 12:19
still doesn't work
2017-6-30
Geebax
There is an Allen grub screw that fastens the gimbal assembly to the motor shaft at the top, it is in a tiny recess. If you loosen that screw you can minutely adjust the roration of the gimbal to straighten it.
2017-6-30
fans536dd43d
Geebax Posted at 2017-6-30 15:51
Thank you - that's way more help than th3 standard CS send it back to us! I'll give that a try.
2017-6-30
GBuck
Flight distance : 6332 ft
Hi Geebax,
Could you post a picture where this grub screw is please.
2017-7-19
