fans29fd0e5c
quadpilot Posted at 2017-7-28 07:54
yes it was showing on the version before the update and also on the latest update
that i did.. new to all this what is the map used for, and what does it do, and how does it work?
sorry for the stupid question any help and advice would be nice
With the maps, your are able to see first your position and after the line from your departure to where your are when your drone is in the sky. This helps you when you want to come back home. Using your map, you can see a line indicating all your movement and from this infomation, heading where you want to go. In other words, if you don't have a map and lose eye contact of your drone, it could be very difficult to fly not knowing what is your direction/position. Without a map, you can fly but make sure to always have your drone in eye contact view otherwise, you can always hit the button Return Home and the drone will come back by itself. But First before flying, make sure you set your altitude hight enought because if this option is set to low, your drone could hit trees or other object while coming back at home on Return Home mode. Yes, the map is very important... |
