Donnie *
Flight distance : 3636782 ft
Tima_007 Posted at 2017-10-3 12:30
Did you read my post???
I told thet all whas good untill i update my go app on ipad air pro and at this time AC and RC still at old firmware!
RC and AC OLD firmware!!!
Tima 007- you ask me "Did You read My Post" ?????( I assume you mean post #10 or #8 ) You NEVER mentioned that you updated the Go app only.... as the matter of fact you say ...."I have the same firmware, nothing update and big issue from nowher!" and you say that you are on old FirmWare, .
You are NOT on old FW ( old Fw could be as old as version 1.2 ) if the "About" tab curretnly says 1.9.0.3 +. The plus(+) sign indicates that the AC was updated but not yet confirmed by DJI servers . If the AC was updated but NOT the RC transmitter it could cause Image transmisssion problem as well. That is why I mentioned to list the FW versions from the "About" tab.
If the RC and AC are on compatible FW then once again the issue goes back to the Go app device . . ( however insane you may think it to be )
Now I understand you are frustarted , but lets try to solve the issue .
There are MANY , MANY factors that can casue the Image transmission problems, I usually start with what has worked in most cases and start there and work my way to more obscure things that may be causing it . All I can do is tell you what works and give you clues on where to look , whether you take my advice or not is totally up to you
****Below is a sample from old FW update on my system the "About" tab , can you please take a screen shot or list the FW versions . This way we can see if it is a FW problem or indeed something perhaps with the Go app device.
Good luck
donnie
