Firmware question
1182 7 2017-6-30
Edit Room
Sweden
Hi again!
Another neewbie question:
In the Dji Go App the firmware says 1.5.0.90 But the latest firmware says 1.10.2.60. Is it supposed to say different numbers or is it a very old firmware installed?
Tried to install the latest firmware (1.10.2.60) but the update process doesn't even start.
Anyone here that could straighten this out for me?
Thank's!
2017-6-30
Håkan K
Flight distance : 262946 ft
Sweden
Did you download the new firmware from DJI, unzipped the bin file and put that in the root of your formatted SD card then started up your Osmo?  OSMO Firmware v1.10.2.60 is the latest and I updated mine in that way without issues. There is a readme on how to upgrade on the same page you download the FW.
2017-7-1
The latest firmware of Osmo is V1.10.2.60, V1.5.0.90 is the latest version of Osmo+.
2017-7-2
Edit Room
Sweden
Håkan K Posted at 2017-7-1 01:41
Thank's for the suggestion!
Yes I did the correct way.
2017-7-2
Edit Room
Sweden
DJI Mindy Posted at 2017-7-2 04:21
Ok, thank's!
I have the Osmo+, thought it was the same firmware for both of them.
Didn't see a specific downlead for the Osmo+
2017-7-2
Edit Room Posted at 2017-7-2 08:43
Ok, thank's!
They are different, V1.5.0.90 is the latest version of Osmo+, you don't need to update again.
Should you have any further questions, please feel free to let us know.
2017-7-2
Edit Room
Sweden
Thank's a million!
2017-7-2
sam143569
Hey guys I noticed issue regarding this firmware.
Trigger is locking orientation for all mode EXCEPT timelapse mode. I did try to manually select orientation lock and same results.
If I downgrade the firmware issue gets solved. I did it multipletime and confirmed same observation. So clearly this firmware has issue.
http://forum.dji.com/thread-105525-1-1.html
2017-7-21
