DJI Thor
Flight distance : 13602 ft
Hi Alex, what firmware is your drone now? Gimbal can be controlled when you allow the option the by our latest firmware.
If you did not update the firmware, did the gimbal work fine during the normal flight? Gimbal mode influences the performance of the gimbal. If gimbal is in FPV mode, gimbal will tilt along with the craft; follow mode on the contrary. Both gimble modes can not control the gimbal at aircraft's Fixed-wing Mode. |
