Young66
You can try the best DJI Phantom 4 Pro video converter.
> This 4K h.265 converter enable you to transcode video of Phantom 4 Pro in H265 to a format more suited to editing videos even on lower spec PCs and keep original 4K resolution. It needs a lot more space for transcoding.
> This software supports resizing video of Phantom 4 Pro in H265 from 4K to 1080p (full HD) and simultaneously save it with editable format like ProRes. In This will speed up a lot of processing the video in the editing software and also lesser PC powerful can work good.
> Join multiple Phantom 4 Pro H265 videos into one. If you format the SD card in fat 32 the video recording limit in size stops at 4GB or so, then because of the file system tree instead of a single video you will find more multiple videos each of 4GB, to merge 2 or more Phantom 4 Pro H265 format files in one final video, you can also apply Brorsoft Video Converter with its "Merge into one file" function.
> Convert P4P H.265 to Windows Media Player, YouTube, etc friendly format for easier playback and sharing. Not all media players yet support fully the H.265, YouTube and Windows Media Player do not support h.265. It is useless to play or send a video of Phantom 4 Pro in H265 on Windows Media Player, Youtube because it is not recognized. This powerful Phantom 4 Pro h.265 decoder brings you a smooth H.265 conversion process. |
