Malakai_UK
Flight distance : 536115 ft
DJI Natalia Posted at 2017-7-5 18:55
Thank you for the data, we analyzed that, please takeoff the drone and make sure it's flying at least 2 meters above the ground then select QuickShot--Dronie, it should work fine.
If you still have the same situation, please keep me posted, thank you.
Ill test it from 2m and above later, I'm quite certain that the few times I tried to do the dronie I tried it at just about 2m, 3m and 4m, in front of me and overhead when starting dronie producing the same result, just flying backwards and only gaining maybe 1m.
The gaining height wasn't my main concern, its how far it went backwards, and its quite a big one!
I set it to 10m and it went 20m backwards!! What if there had been a building at 15m?
Another thing that didn't happen, it said it was returning to the start point and it didn't. I had to manually bring it back in.
Honestly DJI Natalia, do you think this is acceptable? |
