Landing Gear Problem
707 4 2017-7-5
Jeff
Having troubles putting the drone into travel mode, when instructed to it begins extending its hyrdolic arms, only to revert to its landing position, it does switch to flight mode when in the air, and into landing mode when coming down. All software is up to date and no rough landings or crashes, nothing like this in the past.
Regards, Jeff.
2017-7-5
RichJ53
Flight distance : 1837356 ft
Check and see if the BPs is enabled in the Go App, also, check the VPS sensors on the bottom of the aircraft to make sure they are clean.
Another thing that can mess with you is the surface it is setting on/ Try it on top of the case lid.
Rich
2017-7-5
Besides, please avoid putting the drone upon blanket which may absorb sound waves , make sure the surface is with clear patterns or texture.
Please keep us posted if the problem will be solved.
2017-7-5
Jeff
I've tried multiple surfaces including tile, the box it came with, carpet, and dirt.
2017-7-6
PPP
Flight distance : 35217 ft
Try to put a piece of paper underneath the vision system
2017-7-7
