dtb1970
Hi all, I was gifted a P3P, and have just updated the firmware on it. The problem is that the firmware on the remote controller is all the way back to 1.1.8, and will not update with the newest firmware file. I get a text output file on the SD card that says the firmware on the SD card is the same or older as what's on the remote, even though it's not. I am guessing that maybe when it tries to update, it sees the first numbers as simply "118", compared to the beginning numbers of "111" I'm trying to use, and stops there? Tried all three methods of updating, but no dice, and it won't connect to the P3P now.
Seems like from the research I've done, I need to use the 1.3.20 firmware on the remote controller first, and then update the rest of the way from there? The problem is, I can't find that version of the firmware anywhere at all, only the newest 1.11.20 version. Hoping someone knows of a sneaky link I can snag it from and hopefully get this thing working again. I'm pretty new to this, so any help would be appreciated! |
