Punchbuggy
Flight distance : 483166 ft
JockC Posted at 2017-7-6 18:52
I'm considering updating but just want to check the sequence. I prefer using the DJI Assistant where possible. Is the following sequence correct?
1. Update to latest DJI Go4
Jock, some will suggest that the RC and P4 update are the other way around, but as the other is not powered on at the time, I don't see that it matters.
Be prepared to do a manual re-link with the P4 following though - done using C1+C2+Record and when the LED is flashing blue, pressing the link button on the P4.
Also, it'll incorporate a battery firmware update. After you successfully update the P4, power it down, swap batteries (if you have more than one), and power up again. Then just use Assistant 2 to refresh the update.
And this is all just a repeat of what happened with the latest P4P update, so if you strike hassles you can always research in that forum. I didn't have any issues with update of my P4P BTW.
