Electro-Nick
Flight distance : 5989180 ft
If this happens to you after take-off, then try setting the gimbal to free mode instead of Follow Mode. If the aircraft can then turn freely, but stops turning again if you set the gimbal back to follow mode, do the following....
In DJI Go, Go to main controller (cloverleaf icon)->advanced settings -> sensitivity and check the value for Gimbal Yaw Smoothness in Follow Mode, needs to be below 40-50 to allow the aircraft to yaw. If it's much above that, then the aircraft begins to stop reacting toyaw commands. experiment with a value that's suits how smooth you want the camera gimbal to start/stop turning when you turn the aircraft, 0 is abrupt stop without any damping.
Hope that helps. |
