Aircraft totally unstable and aggressive after recent firmware up...
118366 1921 2017-7-8
Júlio Haesbaert
Flight distance : 12533 ft
Norway
Very unstable, loosing connection frequently in short distances, loosing image also in short range, this last upgrade really sucks, hope I dont loose my equipment because of this.
2017-7-14
Aardvark
Flight distance : 384432 ft
MikeW2 Posted at 2017-7-14 00:46
Are these issues related to all the P4's? Not everyone identifies the P4 (P4, Advanced, Pro).
I have the original Phantom 4, and was planning on getting the P4 Pro with the build in display on the controller.
"Are these issues related to all the P4's? Not everyone identifies the P4 (P4, Advanced, Pro)."
This is the P4 section of the forum, so it's fairly safe to assume its P4 and not the P4P or P4A.
They may not have 50 versions of aircraft, but there are a multitude of devices and their operating systems that can be used to control things. So there is always potential for errors.
A good number here are chasing an instability of flight problem, this is something I don't see, but I have (I believe) another problem where the Gimbal seems to randomly re-boot during recording.
The P4P+ (the + indicates built in controller) may have some issues of its own in relation to the built in Android device. Have a search in the P4 Pro section of forum (have a look at top of web page).
2017-7-14
wangrincreation
Flight distance : 984436 ft
DJI Natalia Posted at 2017-7-14 00:22
We need the flight logs before aircraft was updated.
Would you please export 2 or 3 logs to us? Appreciate it.
I would love to  export  you some logs but assistant 2 doesn't list me all the logs. I can  see my logs from the upgrade day to today. I also uninstall/reinstall assistant, maybe why i can't find the ones before the update. Do you know if there is a way to get them?  I can see all my logs from GO4...
2017-7-14
DJI Natalia
Flight distance : 318 ft
wangrincreation Posted at 2017-7-14 01:32
Sorry to hear that the logs before upgrading are not available.
I replied another customer for the logs as well, waiting to his reply, hope he can export the logs needed.
Appreciate your update as well.
2017-7-14
fans90b2bb2d
Flight distance : 599449 ft
Natalia, I have some logs saved on my computer from before the update. Would those help? Thanks for the update! I can probably get the logs later tonight.
2017-7-14
fans90b2bb2d
My drone's stability was affected by the update, and those logs would be from when it was flying okay before the update.
2017-7-14
Moshe.mmm
Flight distance : 1320098 ft
Israel
DJI Natalia Posted at 2017-7-14 00:18
Here is an update:
We need the flight logs before aircraft was upgraded.
Would you please run assistant 2, then export 2 or 3 logs before the upgrading? You can refer to the date to choose the correct logs.
Thank you for your update. It really means a lot to us to know that you are working on the problem for us all, as the issue is a safety issue.
Guys, let's try to expedite the fix. Anyone who can send the data of the drone before the update, please kindly do so.
2017-7-14
wangrincreation
Moshe.mmm Posted at 2017-7-14 02:03
Please Guys, if you have some logs before applying the last firmware upgrade, please post them here, so Nathalia can forward them to DJI engineers. Remember they already have the logs for the update...
2017-7-14
DJI Natalia
fans90b2bb2d Posted at 2017-7-14 02:00
That would be great, waiting to hear from you.
Please click "Reply" button so I can get a remind as well, thanks.
2017-7-14
fanse6d23c78
Flight distance : 585745 ft
DJI Natalia Posted at 2017-7-14 02:40
Phantom 4 experiencing erratic stability issues as already described.
Logs BEFORE firmware upgrade (22/06/2016)
https://www.dropbox.com/s/t3l6gb ... 4_11-33-24.DAT?dl=0
Logs AFTER firmware upgrade (10/07/2017)
https://www.dropbox.com/s/80s5tb ... 1_08-48-31.DAT?dl=0
Can you give us any timeline for a solution? I am losing business because I can't use my aircraft for work.
Thanks,
Peter
2017-7-14
Pareja IV
Flight distance : 1084961 ft
fanse6d23c78 Posted at 2017-7-14 02:51
Meanwhile they could give us the possibility of downgrading to the previous firmware
2017-7-14
fanse6d23c78
Sorry - just a note - the before log date should read 22/06/2017 (not 2016).
2017-7-14
DJI Natalia
Sorry, I'm not able to access to your links.
2017-7-14
Aardvark
Dropbox is showing a '404' error , files not found.
2017-7-14
DJI Natalia
Mabou2 Posted at 2017-7-8 11:32
https://vimeo.com/224777057
Although the problem I am seeing is more subtle than what Moshe is seeing, it is still brand new to this update.  The drone "bucks" once in a while. Here is a 60 second video which shows the problem with the bucking of the P4 after successfully completing all update, IMU and Compass calibrations, etc.
Mabou, we care much about this case and would love to get the flight logs analyzed, would you please help us export 2 flight logs before firmware upgrading, then export the logs showing the situation for the video you uploaded?
Truly appreciate your support and patience, thank you in advance!
2017-7-14
fanse6d23c78
DJI Natalia Posted at 2017-7-14 03:15
Apologies, please try again links again
Logs BEFORE firmware upgrade (22/06/2017)
Dropbox link
Dropbox link
2017-7-14
Elsmeghead
Flight distance : 3421503 ft
[[[SOLUTION!!!]]] (for the camera/fan/gimbal error)
I have just run a series of tests on the Video Resolution Settings.
Please check the video resolution that you are filming at...?
I ran a 4 minute recording on each of the resolutions and frame rates and in my tests the error ONLY appears whilst filming at...
3840x2160 @30fps
Please try altering your video resolution to a different value / frame rate than the one above and let me know if the problem persists.
2017-7-14
Aardvark
Elsmeghead Posted at 2017-7-14 03:35
You're just too clever
I'll have a play here and see what the outcome is, I was just in process of starting a new thread to collate all information.
The problem is very intermittent for me, my thought was working down the line of being heat related perhaps. Which could tie in with what you've seen. That 4k @30fps is very demanding on processor.
2017-7-14
Pareja IV
I'll try in the next flights.
2017-7-14
F.KOK
Flight distance : 18878960 ft
Namibia
I will upload now and sent the data before the update.
2017-7-14
Elsmeghead
Aardvark Posted at 2017-7-14 03:40
I was working on the assumption it might be a video buffer error in the firmware...
I wonder if DJI need a product tester lol
2017-7-14
DJI Natalia
fanse6d23c78 Posted at 2017-7-14 03:32
Appreciate it.
Just to verify, do you have video showing the shaking situation? if so, please provide me the video as well at your most convenience?
2017-7-14
DJI Natalia
F.KOK Posted at 2017-7-14 03:46
Thank you for your support.
It would be better to provide us all the info needed from the same aircraft.
1. Two logs before firmware upgrading.
2. The logs and video showing the shaking after firmware upgrading.
2017-7-14
Elsmeghead
I also checked the max resolution of 4096x2160 @24fps. Normally error occurs within 60 seconds of recording starting... Error nowhere to be seen in a 5 minute test.
2017-7-14
Aardvark
Elsmeghead Posted at 2017-7-14 03:59
I'll open a new thread, those affected can post their experiences. Otherwise this might get lost in the 'instability fault' department...
2017-7-14
brunobaptista
Flight distance : 1369839 ft
Brazil
I have upgraded, but was not able to do a proper test flight yet.
I performed all aircraft calibrations (including VPS). All went OK.
While doing an RC calibration (aircraft off) just now, I noticed that on the first movements up and down of the right stick there was a lot of movement on the left-right readings as if I was also moving sideways the stick when going just up and down (but I was not). As I progressed on the calibration, moving the right stick up and down, those side readings all but disappeared. Maybe this can point to some cause of the jerkiness in the front and back movements?
I will be able to fly later today and will report what happens.
2017-7-14
F.KOK
Namibia
DJI Natalia Posted at 2017-7-14 03:54
Natalia when I want to upload the data there is no data before the 7th when the upgrade came
2017-7-14
SajidShah
Flight distance : 627539 ft
Portugal
Now a days DJI Tech Team even dont care what is happening around .. seems the released new firmware without checking and we have To pay for that really Sick
2017-7-14
Windy Hill Flye
Flight distance : 14764 ft
Aardvark Posted at 2017-7-13 23:49
Are you sure that wasn't the new Landing Protection, and Precision Landing flight functions your were seeing ?
With these features, new to the P4. Aircraft is supposed to return home, and if it detects the landing point could be 'hazardous' it then manoeuvres itself to a new what it detects 'safe' position.
It landed right where it took off from,  it was in an open field mostly bare dirt and a few weeds.  I tried video taping it the next time it landed and of course it went straight down.
2017-7-14
fanse6d23c78
DJI Natalia Posted at 2017-7-14 03:51
Appreciate it.
No video to support the shaking situation. Only logs... sorry!
2017-7-14
rosen9449
Flight distance : 693832 ft
Bulgaria
Hello,
constantly my P4 tells me that there is a strong wind !! This happens on every flight! Quite unpleasant! The weather is very sunless without wind! This happened after I updated with the new version ??? How can I work this way? This is untenable !!!
2017-7-14
usarfireman
Flight distance : 79957 ft
Updated mine a couple of days ago, tried flying it today to unstable to use, wind warming in slightest breeze, imu error every time I start up calibrated IMU so many times now, video dropping out a few feet away and that resets it to photo mode, wobbling all over the place in flight and to top it all tested it in sport mode and it flipped over in flight for no reason and crashed into some bushes luckily only broke a blade. DJI listen to your customers put the old firmware back on assistant 2, I''m on holiday and all this is drone is doing is taking up space as totally useless now and scared to fly it.
2017-7-14
AerialImageryMe
Here is an update:
The files are too large for Dropbox. I have both before and after. The before are the flight files, the after are a combo of flight data and visual or whatever it downloaded. Any other suggestions on how to get them to you? This is a very serious situation.
2017-7-14
fansfe7cbc85
Flight distance : 154291 ft
I was on line with DJI On-Line support last night. Tried 5 different things (all calibrations, restore factory settings, refresh, etc. NOTHING WORKED! I constantly lose signal. Almost every 20 to 30 seconds. Comes back, lose it again. They finally told me it must be my Android Turbo.   So wanted to down-rev. Not available!
2017-7-14
wangrincreation
AerialImageryMe Posted at 2017-7-14 12:56
how about using individual log and zip with winrar?
2017-7-14
AerialImageryMe
fansfe7cbc85 Posted at 2017-7-14 13:08
Online support is useless. They just go by a sheet or something. "Did you turn it off and turn it back on again?" Things like that.
Last they said, just downgrade. I said, you can't. They thought you could.....they are clueless.
2017-7-14
AerialImageryMe
Here is an update:
Before and After Files....
https://www.dropbox.com/s/my2shu ... 4_17-04-49.DAT?dl=0
https://www.dropbox.com/s/ate1w8 ... 4_17-03-54.DAT?dl=0
2017-7-14
Callatis
Flight distance : 511112 ft
luisFOSoares Posted at 2017-7-14 00:04
Sorry but thats not an iPad 2 for sure
iPad 2 is not compatible with iOS 10 . I wish it was
My fault, sorry. It's an iPad Air.
2017-7-14
Callatis
After re-linking the RC I went out for another test:
- every time I turn it on I get IMU error but that goes away after IMU warms up. I did several calibrations.
- it's less noisy
- it auto-lends smoother
- in Tripod mode works well
- in Draw Mode, at the end of the mission it wobbles a lot and it stops wobbling as soon as you cancel the mode.
- in Normal mode, I was flying forward at 40m height and it suddenly accelerates and it goes on one side. I can regain control but it's scary.
There are too many reports of malfunction to be just user error.
2017-7-14
wangrincreation
It's like the wobbling issue is related to Obstacle Avoidance sensor. When OA is disabled, the wobbling will stop but the P4 will act like on sport mode.  Can someone test with the OA disabled?
2017-7-14
