Aircraft totally unstable and aggressive after recent firmware up...
Jgrimmy
Flight distance : 90653 ft
fans987d278a Posted at 2017-7-16 09:46
I wasn't in the air for 3 minutes before I noticed all these new firmware issues too,
Luckily, I;ve been able to downgrade firmware & she's flying as before,rock solid, might be just me but seems faster too.
I;m not even going to think about upgrading again!
How did you downgrade?
2017-7-16
AerialImageryMe
I have heard of two work-arounds for this. Let us know if it works
1. Easy - Let the drone sit after start up. It will record home point.....let it sit, wait until you get the "ready to fly" message. (I have not tried this, but that is one thing I have not seen since update. I just take off after home point is set. I also noticed it records another home point just after liftoff.)
2. A little more work - Refresh firmware update WITHOUT a SD card in aircraft. Then do the IMU and compass calibration. IMU on flat ground, floor or table. Compass outside no where near metal (metal is in a lot of sidewalks). Then fly the drone to test it out WITHOUT a SD card. If it works, land it, shut it down and put in SD card. (I am working on this one right now, will let you all know if it works.)
2017-7-16
Jgrimmy
Updated firmware, calibrated everything, relinked.  Now.......
1.  I receive the message IMU error-recalibrate message briefly every time I start, It goes away after a few seconds.  I have calibrated it several times.
2. It seems to be very aggressive in flight, The front props are appearing in the video on forward flight, this has never happened before in P mode.
3. Unstable hover.
4. Constant wind warnings!!!  In nearly perfectly still air.
What have you done to my perfectly stable smooth flying P4?
2017-7-16
Cian McLiam
Flight distance : 366496 ft
AerialImageryMe Posted at 2017-7-16 12:08
Neither of these two options worked for me
2017-7-16
fans90b2bb2d
Flight distance : 599449 ft
DJI Natalia Posted at 2017-7-14 02:40
That would be great, waiting to hear from you.
Please click "Reply" button so I can get a remind as well, thanks.
DJI Flight Logs Before/After
DJI Natalia,
Here are a couple of my logs.  Two before, and Two after in their respective folders.  I have no video for the logs before the update.
There are two logs in the "After update" folder.  The earlier one is the same flight log as my video post earlier.  If you can't find it, it's this video:
The later log is a normal flight mostly in Tri-pod mode.  There was almost no wind, so it actually flew okay.  There were a few wiggles and wobbles, but nothing major.  I actually thought it wasn't acting too strange at all...until I switched over to P-mode and came down at full speed.  At one point during the decent, it looked like the drone almost flipped over and had a motor surge to correct itself.  I don't have a video of that, but it might be useful to look at the logs.
Please let me know if your team makes any progress with this issue! If you need any other logs/videos from me, I'd be happy to help.
2017-7-16
AerialImageryMe
I tried both of these.
2. It seemed to fly much better without SD card. I thought it was fixed. Put in SD card, flew unstable again. Maybe I just didn't fly it enough to test it.
A few observations that may help solve this erratic and bucky behavior.
- There is no "Ready to fly" message any more. I waited 5 minutes with P4 powered up. Nothing. I waited 5 minutes with motors started. Nothing
- Continuous beeping (motors running) prior to takeoff with nothing showing on monitor for obstical avoidance.
- P4 initially sets "home point". Then when I go to take off, it resets home point at about 3 feet off the ground.
2017-7-16
Jcostello
Flight distance : 1861490 ft
Jeeeeeezzz i thought id got away with this update but after a flight today its now telling me ive got to update
2017-7-16
AerialImageryMe
fans90b2bb2d Posted at 2017-7-16 12:52
DJI Natalia,
Great example of the issue!
2017-7-16
AerialImageryMe
Cian McLiam Posted at 2017-7-16 12:52
Yea, I thought the SD card trick would work, it seemed to, but after I put the SD card back in, it was bad again.
2017-7-16
SajidShah
Flight distance : 627539 ft
Portugal
its a big shame for DJI casue the even dont care what is happening with users . they are busy to sell spark and make video for it .. its like every product when its not famous they always care for clients . when successful they even dont care who the hell are u.. dji support is a big joke if u say my drone dont show light anything .. same answer when u bough drone we arrange rma for u send us back to check lOL .
DJI Give free drones to lot of youtubers and blogers they also can ask them for test there firmware when there is no error can send all users to update ..
this weekend i had fly and some work but can do cause dji drone with new firmware ............................................................................... u can understand
2017-7-16
Gablopez
Flight distance : 515679 ft
Same here, updated, calibrated, etc... Very instable after the update.
2017-7-16
DJI Natalia
Flight distance : 318 ft
DJI Natalia,
Thank you very much about that, I have forwarded all the info to engineers.
Will get back to you once I hear from them, thanks.
2017-7-17
DJI Natalia
Gablopez Posted at 2017-7-16 18:24
https://youtu.be/qpEjGQPY2WQ
Thank for making this video, could you please export the 2 logs before and after upgrading respectively?
We care much about this feedback and working on it now.
2017-7-17
pgrog
Flight distance : 585745 ft
DJI Natalia Posted at 2017-7-17 00:07
Hi Natalia,
This issue is becoming a problem for my business. It is costing my money. My aircraft can not fly and because of this I have to contract 3rd party operators to complete work for my clients.
We need one of the following actions:
1. A new firmware upgrade with this issue fixed
or...
2. A way to downgrade to last working firmware
Can you please let us know when we can expect an update from the technical team?
Thanks,
Peter
2017-7-17
Crazyant
Flight distance : 852392 ft
Cyprus
This is rediculous. We still have no updates and no option to rollback.
I have damages of USD 15K so far for non fullfilled contracts and I am in discussions with a lawyer about this against DJI. Not to forget is that before the upgrade there was a message saying you can always rollback to the previous firmware which is not the case. False claims.
Please allow rollback otherwise we will claim for false claims and damages.
2017-7-17
Icer
Flight distance : 431079 ft
Latvia
Hi. I have same problem with my P4 after updating new firmware v02.00.0106. All update steps was done within instruction. Update went without any errors and problems. All calibrations was done fine. But then test flight, get problem with P4 erratic shaking in the air. Drone is very unstable and during flight make very fast engine rpm small changes that cause erratic shaking. Later try to several time do factory reset and firmware refresh with all calibrations, but all this not give positive result. At this time drone is unusable because of safety. DJI please give our opportunity to downgrade firmware to previous version until new firmware will be fixed.
Thank you.
2017-7-17
Sukhoj T-50
Russia
Does any of the RND test updates before releasing them?
Here are a few problems with my P4:
- problems with the camera, the lens goes to the left and the camera reloads.
- not stable (dangerous tongue), vibration.
- breakage of video communication in 300 meters.
2017-7-17
Crazyant
Cyprus
Heres a video i did https://youtu.be/CDquFCRvph0
2017-7-17
brunobaptista
Flight distance : 1369839 ft
Brazil
I have done a second IMU calibration, this time paying much attention to the pictures and following EXACTLY what was shown in each step. I started with the P4 facing me, and kept all orientations strictly as shown.
My flight tests were with much wind and it performed flawlessly. The gimbal horizon is definitely improved. Horizontal forward flight appeared to be fine, even in strong winds.
2017-7-17
Moshe.mmm
Flight distance : 1320098 ft
Israel
DJI Natalia Posted at 2017-7-14 18:15
No problem, I have forwarded the data to engineers for further analysis.
Hi Natalia,
Can you please update me on status of the issue? I'm affraid to use the aircraft.
2017-7-17
Slipstrm111
Flight distance : 5256 ft
10 days unflyable and no option to roll back with my DJI assistant2.
2017-7-17
vfrailing
Flight distance : 2564442 ft
Cian McLiam Posted at 2017-7-16 09:53
How were you able to downgrade?
I just saw this reply, have to go out for a "blue hour" shoot, will return and verify.  But I remember, after linking up with Assistant 2, and it recognizing the aircraft, clicking on the "versions" tab, and it showing the versions currently loaded.  There was a checkbox next to "downgrade" as I recall.  It was actually quite painless.
2017-7-17
G1DTF
Flight distance : 230151 ft
vfrailing Posted at 2017-7-17 15:26
Can you confirm what version of Assistant 2 you have installed that let you downgrade the P4 firmware. Most others have reported that they have no option to downgrade. I have not yet upgraded so cannot check out the downgrade option.
2017-7-17
Oz Phantom
Flight distance : 79462 ft
G1DTF Posted at 2017-7-17 16:33
I also no longer have a downgrade option, this was previously available but no longer an option for me
2017-7-17
Jgrimmy
That option disappeared for me.  Wish it hadn't.
2017-7-17
vfrailing
Oz Phantom Posted at 2017-7-17 17:12
Am using version V1.0.9
2017-7-17
Gablopez
Natalia, here are the links to the logs:
Before update: https://www.dropbox.com/s/j9ku5v ... foreUpdate.DAT?dl=0
After Update: https://www.dropbox.com/s/7ys6gv ... ter_Update.DAT?dl=0
2017-7-17
Oz Phantom
test flight in remote location with no signal interference and no wifi today - I am glad to report that I had no flight issues at all- I couldnt even get off the ground - the remote would not connect with my ipad or iphone- its 100% bricked now, please do not reply to this comment telling me how you love DJI and there is nothing wrong with your P4 its of no help or interest to me and many others at all.
2017-7-17
Punchbuggy
Flight distance : 483166 ft
vfrailing Posted at 2017-7-15 18:26
JodkC, I have been able to downgrade after the update, through Assistant 2.
After the update, it seemed to hover erratically,  suddenly changing altitude (by at least 5 feet) without any input from controller.  I was flying in a rather tight place, so I immediately brought it back.  Next flight, camera gimbal suddenly went askew.  I was yawing around doing a 180 panoramic series, when suddenly, the camera gimbal got stuck on the side so that all I could see were the landing gear.  The bird began flying erratically, so I felt lucky to get it back.  I immediately downgraded the version on the aircraft, and have had no issues since.  Not sure when I will reinstall the upgrade, until I hear these issues have been dealt with.
Hi. Are you referring to successful downgrade of a P4 or a P4P? I ask because your registration details don't state that you own a P4, and this thread relates to a P4 firmware release.
2017-7-17
JockC
Flight distance : 459416 ft
Punchbuggy Posted at 2017-7-17 21:52
Edit N/A
2017-7-17
KenTbk
Flight distance : 327644 ft
Singapore
Seems like is better not to update mine first. hope there is a fix for this else it is dangerous to take off with this glitch
2017-7-17
Otto4
Flight distance : 162812 ft
Norway
anyone that has older software on the computer or tablet for the phantom 4
2017-7-18
fans72310882
I did the update, and I'm having the unstable flight issue as well. It's extremely shaky, but not to the point where I think it's going to flip upside down and become a flying brick......I hope.  I could almost live with that. What I can't live with is the CONSTANT video freezing, the constant wind warnings when there's virtually no wind, and every once in a while, the camera just goes limp and won't do anything until a complete reset is done. As it is now, it's an extremely expensive coffee table ornament.
2017-7-18
Crazyant
Switzerland
Flew today again. Surprisingly it is very stable. What i did was to calibrate again the IMU when cold and did all sorts of calibrations. Also formatted the sd card.
2017-7-18
DJI Natalia
Gablopez Posted at 2017-7-17 19:03
Before update: https://www.dropbox.com/s/j9ku5vkf3go7ce9/DJI_ASSISTANT_EXPORT_FILE_2017-07-17_22-21-05_BeforeUpdate.DAT?dl=0
Thank you, I forwarded it to engineers already.
2017-7-18
DJI Natalia
Moshe.mmm Posted at 2017-7-17 12:59
Hi Natalia,
Our engineers are working on this case recently, I have forwarded all the logs and videos you provided to them.
We'll update the result to you once hearing from them, thank you very much!
2017-7-18
fans6d4e2456
Flight distance : 546604 ft
Brazil
I updated with great expectations of improvements, because I had serice in another state of Brazil, I was disappointed, presented the same problems already described here. DJI is a silent tomb on the issue.
2017-7-18
Enilson Arneiro
Brazil
After a few minutes with the DJI "expert", asking me if I calibrated IMU, compass, etc, gives me the following answer about my questions about the new update:
"I understand, it just kind strange to me because the new update should fix this issue."
It is not possible that DJI does not know about the problems of the new update.
2017-7-18
GrangerFX
Flight distance : 817713 ft
I am experiencing the same problems everyone else is having. Uneven power during flights. Drone makes a rrr-rrr-rrr-rrr noise as it flies straight and level in normal mode at full stick which it never did before. Video dropped out once at which point it switched from video recording to still camera mode and took a picture of the right legs meaning the camera was tilted all the way to the right and 45 degrees down when it was set to look forwards. I had to manually put it back into video recording mode. My motors now get extremely hot after flight due to all the revving. Top speed in sport mode has been reduced between 5 and 10 MPH. I expect that if I continue to fly my drone in this state, the plastic around the motors will crack due to the heat or the plastic that holds the props on will melt. Either way it means a catastrophic crash, loss or destruction of the drone and possibly injury to anyone who is unfortunate enough to be below it at the time.
This firmware was never tested before it was released. DJI has lost a great deal of my trust. It is not trustworthy enough to force updates, not allow us to downgrade when they now have proven that they are incapable of releasing stable updates. Will DJI replace lost or destroyed Phantom 4 drones that crash due to this firmware? Are they prepared to be liable for any injuries that result?
I said that my P4 now flies like my P2V+ but I now think that it flies like a first gen Parrot Bebop. Did Parrot buy DJI when no one was looking?
2017-7-18
GrangerFX
Please care about updates before you force them on us. These need to be tested. We know that you stopped sending updates to your beta testers months ago so there is no way this version could have been properly tested before it became a mandatory update.
2017-7-18
