Twirlip
Flight distance : 2461545 ft
I got my 5.5" CrystalSky a couple of days ago, flew it for several flights, worked great.
I used the same Velcro solution that I've seen suggested elsewhere; it's a little kludgy-looking but works well enough. Was nicely visible outdoors at noon on a partly-cloudy day. Haven't tried it in full sunlight yet, but I can attest that it's a lot more visible than my phone was. Also, the battery life's amazing, as other folks have pointed out. (Though really annoying that they don't include a charger, and it won't work with the Mavic's charger. Had to order an Inspire charger just to charge up the darn thing.)
I also had the issue with the Chinese maps and no visible streets. The solution was apparently to do a reset and then set the time zone to my local time zone (I'm in the US), then it worked. I did run into some issues after the reset-- the DJI GO 4 app kept insisting it had no network connection and I couldn't sign in, even though the Wi-Fi was definitely connected. (I've seen some other folks on the forum reporting some similar issues.) I just kept banging away at it randomly, i.e. more resets, trying different orders of "first set timezone THEN connect WiFi" or whatever, manually disconnecting/reconnecting WiFi. After an hour of fussing and fuming and trying random variations of pretty much the same thing umpteen times, eventually it worked and then it's been fine since. Got my local maps, no problem. |
