Donnie *
Flight distance : 3636782 ft
NailDrivingMan Posted at 2017-7-10 02:03
Just turned everything on and noticed that g maps required location services to be turned on, so I did that first. Next I went to go app and noticed ANOTHER firmware update is required...SHEESH! I just updated two days ago and now not only firmware, but radio update...AGAIN. I'm hoping that these updates are required to communicate with third party software and not to fix internal DJI conflicts. By now, I have to believe that DJI has worked all the bugs regarding internal conflicts, after all, this technology is three years old. Let's hope. I will do all new updates and report back.
Thanks,
NDM, just wondering , do you have a Maps Icon on the iPad ? if so does it work properly ? Can you zoom in and out on current location ? Also are you up to date on the Go app as well.
Another member had a similar problem after update and I will try to find what solution worked for him , If he found one .....
Can you list the "about tab" you current FW for AC RC and Go APP ? just want to make sure you are on compatible FW .
sounds to me like you updated but may not actually be current ...not sure thats why I want to check . Make sure entire system is on when going to the "About "tab on go app or you wont get complete data .
*****Ok, found possible fix , delete and re install the go app seems to be the answer . If you wish be sure to sync your flight records ( if you wish , not mandatory ) before doing so , another member had the same problem recently .
donnie
