dldp-sp
Flight distance : 1065902 ft
I never had this problem with the stock lens however, after buying the Olympus 45mm lens I started seeing this. The problem for me was a matter of balance. I was using the lens hood that came with the lens and a few rubber bands to balance it. I thought it was balanced good but started seeing the "jello effect". Once I bought the balance rings, the problem went away. Also, if you are using an ND filter, try taking it off and fly with the standard filter ring and see if that helps.
Regards,
Tom |
