Blackwood
While waiting on DJI to fix the CPU bug, sorry I forgot, they call it a feature, I decided to play with the wobbling props. You know, the other issue they say is normal. I decovered that if I put a sliver of paper in the small channel of the prop mounts where the screws are, I could remove all wobble. Looking for something that would last a little longer, I found that if I put a thin strip of electrical tape in the same location but on the underside of the prop, I'd get the same results without resorting to permenently altering the props with something like superglue. I'm sure the tape will eventually fall off or wear out, but it's super easy to replace and now my props are solid. |
