Donnie *
Flight distance : 3636782 ft
Ok , did you read the Release Notes by any chance before updating ? it is good form to always read these first before downloading . ( it just says mey loose settings and to make note of them before updating )
Now you may have simply lost a setting. Lets go over some possible suspects .
First off are you saying you dont have Pan .... exactly when is this ??? On the slave when filming or just on Master
-On the C1 C2 buttons , do you have the Pan tilt assignment on these ? ( under Remote control settings ) If so I would "Not define " them for now and change after we solve this , or make sure the assignment is to your liking from before , If you used it . ( this will go for most suggestions )
- On the "gimbal settings " tab go to the Advanced settings , make sure none of the values are set to zero, I would just set them to the Reset for now ( do it on all three ) . One of these may be set to low and Now NO pan .
also do you have the Pan sync enabled ? If not be sure to enable .
Now double check the camera , make sure you are In follow mode and not FPV or Follow . Very Important
You will find the settings on the go app main screen left side with the "Arrow" Also yo can confirm this on the Gimbal Settings tab of go app, make sure entire system on when checking or you can get a wrong value. Just make sure on Follow .
You dont have other cameras do you ? If you do must update with the other camera FW as well.
I think it is going to be a settings change that has you vexed, lets start here and let me know.
Lets start here .
donnie
